Cold Start injector
Old 12-09-2011 | 10:44 PM
summit4runner's Avatar
Cold Start injector
I have had a problem wih cold starts for a while, after it's warmed up it's fine and can restart fine. When I start it first thing in the morning it will sputter, check engine light on, then warm up and normal (no light, even restarts when warm).
So, with advice from this forum and the FSM I tested my CSI, I got 111, it is supposed to be between 2-4, so I went to Yota yard and got one, checked it there, 223. Came home, put it on, after not driving it for 2 days and 0F, it started right up. Fixed. I tested it 2 more times, great everything working.
Started it today, 10F, problem is back, exactly the same.
What can make a cold start injector go bad?
Am I just unlucky with the Yota yard part?
Should I just try a new one?
Old 12-09-2011 | 11:01 PM
4wd4fun's Avatar
if its suppose to be 2-4 ohm and your old was 111 and the new (used) one is 223 why would you buy one worse than your original?
Old 12-10-2011 | 04:59 AM
fjfodee's Avatar
Check your time switch.
http://personal.utulsa.edu/~nathan-b...ne/39colds.pdf
Old 12-10-2011 | 07:41 AM
fjfodee's Avatar
Also check your coolant temp sensor.
When the CEL comes on, try to pull the code.
Old 12-10-2011 | 08:28 AM
The old one was out of spec, less than 2, the new one was within the 2-4 range, so thats why I bought it.
Old 12-10-2011 | 08:46 AM
Terrys87's Avatar
Staff
Hello Summit... Just got done doing this. I wound up having to replace my timing switch. The old one tested fine. In my 88 thread you will see what it looks like,it is my very last post. Might just need to pull it and give it a good cleaning.
Old 12-11-2011 | 05:17 PM
4wd4fun's Avatar
so old was 1.11 and not 111, and new was 2.23 and not 223?
i'm confused since 1.11 is not 111 and 2.23 is not 223.
Old 12-16-2011 | 11:23 PM
Thanks Terry, that on for my next day off, I'll post how it goes.
Old 12-16-2011 | 11:24 PM
Yeah...I'm not too concerned that it would be that far out of spec, pretty straight forward.
Old 12-16-2011 | 11:41 PM
4wd4fun's Avatar
so it was a misplaced "."? makes sense now. sorry.
does the "new" junkyard one test the same it did or ?
Old 12-16-2011 | 11:46 PM
4wd4fun's Avatar
as for why replacing it worked for a day or two... maybe you lost some fuel from the line when you swapped it and the trapped air kept it from working?
does disconnecting it help your start issue?
Old 12-17-2011 | 06:17 PM
Nothing was misplaced, it doesn't really matter where the zeros are to me, sorry, pretty straightforward once again.
The old one (below spec) was around 1, I don't remember exactly, the new (to me) one from the yard was almost 3, as the specs say between 2-4, that means, the old one was bad and the new one is good.
Old 12-17-2011 | 07:21 PM
GenXr's Avatar
I bet it would matter if you misplaced some washer shaped zeros in your crankcase.
Punctuation is just like traffic rules. Everyone gets along so much better when everyone follows the rules.
Old 12-17-2011 | 08:25 PM
[quote=GenXr;51837092]I bet it would matter if you misplaced some washer shaped zeros in your crankcase.
quote]
Well, I'd have to agree on that one...
Rules are made to be broken .
BushPig
10-29-2022 06:26 AM
bigjstang
08-25-2021 12:41 AM
steve miller
10-10-2015 01:40 AM
Huntingtruckcletus
07-08-2015 05:26 PM
karbin
07-05-2015 11:37 PM
Quick Reply: Cold Start injector
