Cold exhaust on cylinder 3
Old 12-05-2020, 12:07 PM
Jhoward's Avatar
Swapped out the injector on 3. Running great now. Thanks for all the advice for testing the wiring and injector. I posted a pic of the bad injector as well as a pic of an empty blue vacuum post directly behind the passenger side fuel rail. Any idea what connects to that?
Old 12-05-2020, 12:24 PM
2ToyGuy's Avatar
The blue piece in the second picture is some heatshrink on a wire, from what I can see. It looks like it goes to the item directly under it, but I hay be wrong about that.
Good luck!
Pat☺
Old 12-05-2020, 02:19 PM
Jhoward's Avatar
Im pretty sure it’s a vacuum post with 2 ports. Bottom one is connected.
Old 12-05-2020, 02:53 PM
YT Community Team
Jimkola's Avatar
I grabbed the first vacuum schematic I could find, but if you’re looking at the bvsv then I say that one vacuum line ends up at the throttle body and the other at the charcoal canister. But take a look at this and see what you come up with
Old 12-05-2020, 04:45 PM
  #25
Jhoward's Avatar
That’s it. My vacuum canister line was not connected. Thanks. This is a great forum...lots of helpful members.
The following 2 users liked this post by Jhoward:
Jimkola (12-05-2020), old87yota (12-06-2020)
LH0525
17
12-10-2019 10:15 PM
Johnboy80
11
07-14-2016 03:29 PM
Dljy
12
05-26-2015 12:56 PM
Batman
09-13-2008 08:28 PM
Tigerstripe40
04-03-2007 09:42 PM
Quick Reply: Cold exhaust on cylinder 3
