Codes 12 and 13
Codes 12 and 13
I have a 93 yota pickup (4x4,5 speed) and i just did a top rebuild to the engine(22re EFI). originally just to replace my timing chain, but also did new water pump, fuel filter, O2 sensor(pre cat), dist. cap, plugs, plug wires, new belts, new hoses, etc.. Now when i take off from a dead start i lose power in 1st like I'm not getting enough gas (bogs down, rpms drop, truck jerks) but the engine does not die or throw a check engine light. Diagnostics throws a code 12 and 13. This leads me to believe it has something to do with the dist. cap. My friend thinks it is my fuel pump. I don't have the money to take it to a dealership for a hardcore diagnostic check....
Anyone else have similar problems?
If so whats the cheapest fix?
PS. this problem did not occur before the rebuild.
i will post pics/video soon.
depending on if i researched it right, code 12 would be a short circuit in the solenoid relay circuit.
im checking this during my lecture on the schools alldata and im rushing, hope it helps.
I searched the manual and saw this:
12=
Diagnosis,
Open or short in NE circuit
• Distributor
• ECM No NE signal is input to the ECM for 2 secs.
or more after STA turns ON.
Trouble Area
• Distributor
• Open or short in STA circuit
• ECM
13
Diagnosis
NE signal is not input to ECM for 300
msec. or more when engine speed is 1,500
rpm or more.
Trouble Area
• Distributor
• ECM
12=
Diagnosis,
• Distributor
Trouble Area
• Distributor
• ECM
13
Diagnosis
rpm or more.
Trouble Area
• Distributor
• ECM
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
