Clutch trouble
Old 10-19-2007, 07:14 AM
n4ynu1010's Avatar
Clutch Master Cylinder/Slave Cylinder
Originally Posted by RustBucket
Just a quick question - if my MC was leaking internally, would it not just cause the clutch to be hesitant to disengage, not hesitant to engage?
If the MC was bad internally (seal or valve) then it would not depress clutch arm at all , it would depress partially or depress fully/partially and then bleed down/slowly release (the slowly part depends on the condition).
These symptoms could also be experienced by the slave also but in the case of bleed down then there is generally a leak at the slave , and alot of times the slave's piston cylinder housing becomes worn and or varnished which leads to restricted travel (varnish/buildup),restricted travel(piston binding due to wear on cylinder and or seals).
But air can be trapped in hydraulic system of clutch and reduce the travel of the slave cylinder or make the depression of the clutch arm spongy so to speak , if the system is properly bled and there are no leaks at slave and you have a problem with travel of the slave piston/clutch arm then that will generally indicate a bad MC considering you have no leaks witch should be rather evident on that little hydraulic system.
Old 10-19-2007, 09:11 AM
RustBucket's Avatar
Yeah I'm planning on replacing the little flexy hose with a factory part as well, thanks for the input. Hopefully this will solve my problems. Thanks for all the info fellas.
Old 10-19-2007, 09:58 AM
n4ynu1010's Avatar
You will help me one day
Old 10-21-2007, 07:41 PM
RustBucket's Avatar
Just ordered the parts from Marlin's website. Way cheaper than from the stealership.
Old 10-22-2007, 12:56 PM
  #25
n4ynu1010's Avatar
hehehe ..............anywhere cheaper than the stealership but some parts are better from the old stealer but I think your pressure hose for the hydraulic clutch will be fine from them .
Old 10-22-2007, 01:04 PM
  #26
apalmer1's Avatar
if you wana be absolutely sur you have no air holes put some ultraviolet die in the fluid then use a blacklight after driving.
Old 10-23-2007, 06:31 PM
  #27
RustBucket's Avatar
I'll just pick up a little ultraviolet die at WalMart then
Old 10-23-2007, 07:04 PM
  #28
n4ynu1010's Avatar
H
If you use the die you will have to wait a while before testing because circulation in that little (one way) hydraulic system could take quite a while on the other hand if you were to mix the dye in the fluid and drain MC with syringe and refill and then bleed system well it would be distributed throughout the entire system , just after you bleed it if you have some spillage just spray down with degreaser and hose off .
And if you were to do this I would make sure that the dye is going to be compatible with brake fluid as well.
Old 11-04-2007, 07:23 PM
  #29
RustBucket's Avatar
So the problem has slowly worsened to the point that I can only drive the truck with no clutch slipping for about 30 minutes and then the clutch requires bleeding again.
Fortunately, the parts came in and RockoTaco is comin' over to help me tomorrow. Pray that Advance will give me my money back...
Old 11-06-2007, 07:09 PM
  #30
RustBucket's Avatar
Replaced the parts with factory Aisin MC and SC.
Clutch now works correctly
Old 11-09-2007, 07:47 AM
  #31
n4ynu1010's Avatar
Cool
TheBFA
02-15-2020 06:55 AM
Longbed 90
03-11-2019 12:38 PM
hiluxinargentina
09-30-2015 05:51 PM
Matthew Perez
09-28-2015 05:43 PM
Nick Berg
09-03-2015 04:36 AM
Quick Reply: Clutch trouble
