Clutch, Slave Cylinder, or Master?
Old 12-15-2007, 02:06 PM
HAWAIIANSTYLE's Avatar
clutch problems
hi everyone.
i have a 94 4runner, v6. im having some clutch problems. i've changed the master and slave, also bled the system and adjusted the height and play of the pedal,.. still nothing.. is there anything else i should be checking before i tear open the tranny...
Old 12-15-2007, 03:37 PM
"pete f passed away quietly in his sleep on July 13, 2008
pete f's Avatar
Originally Posted by HAWAIIANSTYLE
hi everyone.
I broke my clutch pedal bracket earlier this year. Took some line and put loop around pedal and used the door stop as a pulling point and tied it off measured pedal height I believe it should be 6 inches off angle of floor behind the petal this pulled the crack together .Then I drilled the bracket and thru bolted it to the firewall about an inch from where the plunger for the master goes. I then I got some plumbers epoxy and mixed up and mushed the putty all around the crack . I also put some on the end of the bolt to keep the nut from backing off . It's a temporary fix but it temporary is permanent. It's working great. The putty comes in a tube just break it off mix the two parts and in 15 mins it's as hard as a rock.
Old 12-15-2007, 06:47 PM
TNRabbit's Avatar
OK dude; you've had 6 different ppl tell you clutch bracket and you have yet to say if you even checked it....?????????
Old 05-10-2008, 07:06 AM
mattynicks3's Avatar
Originally Posted by High Water Drifter
here is another possibility: broken/cracked clutch pedal mount. very common problem with 2nd generation toyotas with manual transmission. when this happens truck won't go into gear and makes you think it's a slave problem. your local clutch repair shop can get the part and there is a mod available to strengthen it. hope this helps
yes my mount broke. i just welded it. it broke a second time and i welded it again.
i think its time for a new mounting bracket
09-04-2015 09:27 AM
sqdg71
08-07-2015 01:03 AM
wolfpackfan33
08-02-2015 03:36 PM
Shaun Crystal Gomban
07-30-2015 10:13 PM
HookahRoo
07-20-2015 07:06 PM
Quick Reply: Clutch, Slave Cylinder, or Master?
