clutch replacement
#81
The input shaft is definitely starting to make it's way into the clutch spines, but because we can't get the rotation right it won't be aligned properly to go in.
I wanted to go to ace hardware and get some long bolts (maybe 7 inches) to bolt the engine to the transmission to act as a guide and keep it from rotating. Would that work or would the bolts be at risk of snapping off and breaking?
#83
Nope. No jacks under the engine. I did have one to help tilt it, but that didn't do much.
I ended up pulling the engine off of the engine mounts, removing the exhaust manifold and the radiator/shroud. I put the cross member back and now the transmission and transfer case are installed. Now we just need to get the engine on the splines. This is the part I should be good at, seeing as how I did this 3 times in one week on the subaru. I'm taking a break now before I kill myself from exhaustion.
#84
Gotta stop for today. Too many scratched and cuts to continue. I need to also let this thumbs heal before I can be any more useful on this.
I'm considering getting one of these: http://www.amazon.com/Waterproof-Plu...1311183&sr=8-1 so I can stick the camera in the bell housing and see how close we are to getting it together and see how to move the engine. Would be a very nice tool to have.
#86
I don't have a motorcycle,(thought about getting one) and this week I'm out of work. Tomorrow I actually start a new job, so as I left my last job I intentionally left this week open so I can work on the truck. Tomorrow I'll just be carpooling in the subaru. Carpooling won't be too bad because for the first 3 weeks of training at the new job my schedule will match that of the wife's.
In the meantime, I'm going to go to the hardware store and get a few long bolts to act as a guide. I was reading some "engine/tranny mating" threads and I've found a few references where this technique helped greatly.
#87
Most hardware stores unfortunately will not have what you need. They should be 12mm x 1.25 and the length is up to you.
It really sucks that you couldn't get it to mate up, I hate having bad days when working on stuff.
#88
I'd prefer getting the right sized though, so where would I find those?
#89
Ace Hardware will have those bolts. Not cheap though, about $5 a piece if I remember correctly.
I just had to go buy some so I could mount the block up on a stand.
Good luck, let us know how it goes!
#92
wow!
sorry to hear the frustration. I share your frustration. I am on day 3 of a front end rebuild on my 82. I tore the axle apart then went to unbolt the leafs. well, they would not budge. I did everything from heat to beat and nothing. My hands are so beat up I had to soak them in hot water. I finally cut all four bolts and in the morning I am going to put new bolts in.
This front end should have taken a day it's now going on day 3
SOOO.. I feel your pain. Hang in there, you'll get it.
#93
I also needed custom bolts for my engine stand and am lucky that there is a commercial hardware distributor that has EVERYTHING in stock, I got 4-6" 12x1.25 for $12.00
One thing to constantly look at is to make sure the trans and motor are square to each other both left to right and top to bottom. I know it is hard especially on a jack but the input shaft will not go into the pilot bearing unless they are perfect.
When I just dropped my motor in last week I remember I had to draw them together with the mounting bolts, it would only get to within about a 1/2" of each other but I could not force it anymore and used the bolts to finish the mating.
Never give up, just get angry!
#94
wow!
#95
you, know dave... i was mentioning about your bicylce ... lol
but for your sake.. your head bolts are 12mm x1.25 so just throughing it out there.. most people dont know..
#97
The lower bolts on the transmission are larger than the top two bolts. Does anyone know the size of bolts I'll need for the top and bottom? I left the bolts at my parent's (where I'm doing the repairs) and I'd hate to go all the way there just to pick up the bolts.
Eh, I might just pick them up on my way home, even though it's in the opposite direction. But just for the sake of backups, which sized am I looking for other than 12x1.25?
#98
If you get 4 12mm x 1.25 you should be ok. There are some smaller sized bolts but the 12mm are placed at approximately 45, 135, 225 and 315 degrees and form a square almost.
#100
Today I got the engine back in and the transmission/engine bolted together. Now I'm just wrapping things up and putting all the bolts back where they should go.
I have a problem. I pulled my front propeller shaft out (the one going from the transfer case to the front wheel drive system) and I forgot which way it came out. There's a fat end and a shorter skinner end. Which end goes towards the front? I checked my chilton's manual and couldn't find any diagrams or pictures.
-edit-
I think this helps: http://www.4x4wire.com/toyota/tech/d...mber_large.jpg
But just to confirm, the skinny end points towards the front?
-edit-
