Clutch? Help???
Clutch? Help???
My 94 Pickup has gone again, this time something to do with the clutch. I was driving put it nuetral pressed clutch to put in gear and it went in gear but stalled and clutch pedal never returned to original position. clutch will not stay when pulled out then pressed again it just sits on floor. it feels real soft and loose checked everything under dash, springs levers, etc. looks normal. Please tell me what it could be and how to fix it thank you so much everyone.
My guess is there is a leak in one of the following:
1. Master cylinder
2. Slave cylinder
3. The pipe between these, expecially the flex hose right by the firewall on the passenger side.
1. Master cylinder
2. Slave cylinder
yup, check the master clutch cylinder the lines connecting it to the slave cylinder (on side of transmission bellhousing)
probably find something wrong with em
kawazx636
10-06-2021 03:03 PM
primordialbeast117
12-19-2015 12:23 PM
smilen724
13
11-08-2015 04:11 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
