Cannot remove 3rd member (spot welded?)
IMO, those are some nice looking gears. I'll be surprised if you find them or the rest of the 3rd member too much out of specs. I mean it'll probably need/could use adjustments to all of the bearing PLs and BL, but not likely by a whole lot. Unless there's a shot bearing(s) or something that needs replaced first, it's an easy fix.
BTW, the pinion seal is held in by it's own by tension/friction against the 3rd member housing. Not the preload of the pinion nut.
Thanks. You're such a knowledgeable dude. That 3rd member is the one I considered the worst of the two. When I turn the pinion flange back and forth it has a little more backlash (correct term?) than the one I'm going to put in it. (out of my '94) Also, the one pictured (out of my 92) makes a metallic chunk chunk sound when turning pinion flange back and forth. The "new" one (out of the 94) makes a soft click click sound. Sounds better to me.
Thanks, MH, .....I didn't mean it would fall out or leak if the nut wasn't sealed up to the right torque... I mentioned it cuz of hearing "I blew up my rear end cuz the pinion nut was way too tight/loose", ...stuff like that, lol..Not even sure how all that works, yet, ...learning, ...
See?>> Knew you'd get a good solid "what's what", sooner than later, Victor. lol
jasonty
41
12-23-2018 01:00 PM
jerusry
10-19-2015 05:28 PM
BeMiceElf
10-10-2015 09:40 PM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
