A/C, what potential problems?
I'm looking at buying an 86 4x4 with 22re. The A/C has not been run in a long time and does not work. The owner says it needs a new compressor. OK, that's $300. But will that be all it needs? I'm suspicious that if the ac has been dead for a long time, all the seals are probably shot and I will be looking at a lot more than just the compressor. Am I right? Other than the compressor and a recharge, what else might need to be replaced to get the AC back up and running? Gimme a worst and best case scenario. Thanks.
Most ac shops that service automotive ac flush the system with a special chemical that cleans out whatever is in the system. The filter drier looks like a tall can of beer. You change the unit its non-servicable!!!
