Burning Smell....
Burning Smell....
1994 pickup, 3.0L driving fine but when i parked for the night just now i noticed a burning smell coming from the engine, seems to be coming from the upper right hand corner under the hood, like right behind the air filter... back up siren and alarm siren are mounted here but i do not know what it is , any ideas? the burning smells like a birthday candle if that makes sense,
any help would be great thanks !
go through and look for any wires...thats what a Ground wire burning smells like on my truck..but it was burning because my starter was lagging...new starter..no burning...so check your grounds first..then continue to check other wires..
I have had a similar problem, it has turned out to be the driver's side valve cover gasket leaking and dripping onto the exhaust crossover pipe. I am going to replace it soon. Check it out, might be your problem.
I replaced both valve cover seals it was a pain.
to anyone planning on replacing the valve cover seals get the intake manifold seal at the same time.
sonorn67
09-19-2015 05:39 PM
