Body/mount broken
Body/mount broken
First post here. I searched around online and couldn’t find anyone with the same problem.
Body mounts are off but there is a bigger issue I haven’t seen anybody talk about. The body has seemed to break off the mounts and are not connected at all in some places. I am just curious as to my options or the best way to fix this.
Looks to me like you have a body lift. Not seeing anywhere broken.
I hope that’s the case. But where I’m talking about is the body that the mounts connect to, the body is cracked and broken. Some mounts aren’t even connected to the body. You can see the cracks on the body/sections painted blue. Not the frame. Specifically the 1st and 2nd picture are broken
There is a big gap here this is the worst one where it’s not connected to the body at all
theres a dent in the rear quarter panel I think it was from that. Probably shifted the whole body off. The frame still looks good but that’s just eyeballing it. It sat in the desert for like 15 years and doesn’t have hardly any rust. I’m a new owner.
do you guys think this is fixable or too much of an issue?
get a couple of quotes and a few recommendations for a good welder.
Other member with same problem:
https://www.yotatech.com/forums/f116...-mounts-82172/
I'd like to know why that happened. Body lift too slim? Too high? The wrong one?
Glad you didn't have this problem:
https://www.toyota-4runner.org/class...dangerous.html
hopefully it’s not too bad I would just remove the body lift altogether given the chance. I’m still daily driving it so hopefully that doesn’t happen to me!!!
Remove the body lift junk...
someone can jack the body back up and fab pieces to weld to the body to bolt back to the frame... it doesn't look difficult to me. The truck looks nice, this isn't a big deal. But, it usually isn't when it's somebody else's issue.
The following users liked this post:
Jimkola (02-18-2021)
YT Community Team
Yeah, A bang to the 1/4 panel didn't do that. My guess is the suspension is so stiff that all the engine/powertrain/road vibration is getting directed right to the body. Usually beats up the tires pretty good, too.
waskillywabbit
43
06-13-2011 08:10 PM
4RunnerFever
12
07-11-2006 10:15 AM
