Bleeder-Dude's Official 22re Engine Rebuild Thread - TONS OF PICTURES!!!
Old 08-16-2009, 08:58 PM
  #861
phildelfino's Avatar
Originally Posted by camo31"10.50"
wow...yea..im with you bleeder...i TOTALLY want a couple of those...
but...i'd have to eventually replace the one that i would put on the truck..with a 4.3 VORTEC emblem..lmao..yes...i plan on being a crossbreeder..
Post it up with plenty of pics. Go here for info on everything Toyota. Listings are alphabetical, so scroll down for 4.3L.
http://www.pirate4x4.com/forum/showt...ner+speed+swap
Old 08-16-2009, 09:06 PM
  #862
camo31_10.50's Avatar
oh it wont be for a few years unless i just happen upon a few grand..lol..like 5g's....or 6..lmao..i would do all of the mechanical stuff..and have somebody else do the wiring..because it wouldnt be just a simple TBI4.3..it would be one of those with the badass aluminum intake that says VORTEC.(CPI i think???).LOL..atleast im planning on a 4.3
now if i happen to find a 4bt cummins diesel...well..i'll just have to MAKE IT WORK..(weight wise..lol)..because that is my dream motor..and they take WAYYY less wiring to run GREAT!
mmmm..can you guys imagine..pullin those big a$$ hills and switchback's up the rockies..with a 4cyl..not 22R or RE or REC..but 4BT CUMMINS....wow..it would be a breeze...
Old 08-16-2009, 10:33 PM
  #863
scuba's Avatar
Those videos are badass Travis !!
Glad to see shes doin well
Old 08-19-2009, 04:20 PM
  #864
iamsuperbleeder's Avatar
yaaaay, I stopped all my exhaust leaks this afternoon!
it sounds soooooo much better
now if I can only get these damned valves to shut up, lol
Old 08-19-2009, 04:27 PM
  #865
BigBluePile's Avatar
Lol!!!
Old 08-19-2009, 04:30 PM
  #866
Lumpy's Avatar
Good to hear or in this case not hearing...
Although I have grown to like the little ticking of the valves...it's like the yota love song..."Clicking of the Yota Valves"
Old 08-19-2009, 06:21 PM
  #867
93YotaMonster's Avatar
hey bleeder did you ever get your idle fixed?
Old 08-19-2009, 06:35 PM
  #868
tighten your valves to Ted's spec's...it shut mine up..and im at around 700 miles and when i checked em at 500 they were still tight..so im doin good..lol
Old 08-19-2009, 08:41 PM
  #869
oh yeah, the idle issue a long while back was a shot timing chain tentioner and an exploded driver's side guide it was throwing the cam and dizzy out of sync with the crank
and I'm sure the gnarly caked-up junk on the valves of the old head with 296k miles on it wasn't helping at all either
Old 08-20-2009, 07:13 AM
  #870
Outsane's Avatar
so what did you do to close up the leaks?
Old 08-20-2009, 05:01 PM
  #871
Ended up pulling the header completely off and re-seating the gasket against the head. The main leak was from the PAIR tube block-off plates. I had to make some releif cuts on the bottom of them so that they don't interfear with the welds on the header tubes. I also had to install a new clamp at the mufler as the old one for whatever reason losened up I even went as far as installing a new hanger; I think that's the reason that clamp loosened up, because of a bunch or play and movement in the exhaust system.
But now after driving today there's still a slight header leak; just a slight ticking when on the throttle. I'll retighten the bolts tomorrow after work and see if that stops it though worked for the dang head gasket coolant leak, why wont it work for an exhaust leak, lol
oh also, the CEL's on now... code 21... and I just replaced the O2 sencor about 2 years back... damn Bosch, I knew I shoulda went Denso
Old 08-20-2009, 07:03 PM
  #872
Outsane's Avatar
nice work...
Old 08-21-2009, 12:18 PM
  #873
davo247d's Avatar
lol you should get that beast dyno-ed
Old 08-21-2009, 08:18 PM
  #874
4Krawler's Avatar
X2 on Dyno, but only AFTER about 3K miles....
BTW do you have an adjustable cam gear? If not how did you advance the timing?
Good Work Travis!
Old 08-22-2009, 01:31 AM
  #875
olharleyman's Avatar
Can you pm me them spec's I would like to quite mine down too
Old 08-22-2009, 06:46 AM
  #876
Dirt Driver's Avatar
Yeah, I wouldn't be surprised if it posted low numbers being this fresh. When I dropped a (stock) rebuilt 22RE in my truck that was apparently fairly tight, the economy was down ~2mpg until it had maybe 3,000-5,000 miles on it. I think I have heard that the LS1 Camaros posted higher numbers after the engine was run for a few thousand miles too.
Old 08-30-2009, 07:02 PM
  #877
I really hate to do this... the 91's gotta go...
read the thread...
https://www.yotatech.com/forums/f108.../#post51217586
I want to thank EVERYONE that helped me out on here. You guys have been SOOOOO helpful in getting me to make this truck were it is.
Old 08-30-2009, 07:09 PM
  #878
Tubbyfatty's Avatar
Nooooo! It cant be true. Well good luck dude.
4600 post btw.
Old 08-30-2009, 07:11 PM
  #879
4600 post btw.
thank you man!
yeah, I'm an old fart here on YT
I hope that it'll catch someone's eye here on YT; if it doesn't, it's going on graigslist next... and who know's what kinda person will buy it...
Old 08-30-2009, 07:31 PM
  #880
yoterr's Avatar
ughhh WHYYYY (i know turning point) but good lord you know the hours take that back MONTHS of hard work uve done on it and allmost every nut and bolt on it, it wouldent be worth getting rid of, shoot the little bit ive had mine i would never sell it, just cuz of all the work ive put into it, and its not even a 20th of what uve done
Quick Reply: Bleeder-Dude's Official 22re Engine Rebuild Thread - TONS OF PICTURES!!!
