bigblockyota
Old 07-24-2008, 07:21 AM
  #141
john rumbo's Avatar
Old 08-26-2008, 05:46 PM
  #142
apalmer1's Avatar
on your truck did you use the stock spring locations on the frame? it looks like you extended the hangers out int he pictures to match the chevy spring perches. im in the process of putting full width axles under my 85 and would like to see how you mounted the springs if you made them wider.
Old 08-26-2008, 07:33 PM
  #143
881stGenRunner's Avatar
apalmer1 skys manufacturing sells a full width spring perch so the leaf springs are located farther out. check out their website
Old 08-30-2008, 10:08 AM
  #144
apalmer1's Avatar
good info thanks
Old 09-06-2008, 09:33 PM
  #145
john rumbo's Avatar
sorry so late busy working on other projects and tryin to finish my 4runner just converted the steering i actually built custum brackets to widein mount location and added wider hanger bushings because my truck was ifs when i started wider axles are awsome under the toyotas you will need to up grade steering eventually the toyota wont handle the abuse i went to full hydraulic from psc and custom brackets it works great spool up front and steers like a cadillac
Quick Reply: bigblockyota
