big 22RE problems
Pruney81, I hope not. After flopping back and forth I've pretty much decided to use the Rock gasket on mine. But I may still change my mind.
Pennywiserawker, how did you install yours? Engnbldr posted this advice a while back:
http://www.4x4wire.com/forums/showth...087&page=&vc=1
thinking about finding a 2wd with a bad motor to scoot around in, putting my 22re in it, and getting an LS1 to put in the 4wd but that will be some time from now; I plan on sourcing a motor and getting it together first, which I MIGHT start doing next year I cant just drop a stock LS1 in it
hey pennywiserawker i had the same problem with my 93 22re, it ended up being a cracked head. the head was cracked right between the valves on cylinders 1 2 an 3
#27
30k miles on my crappy Rock products so far and it over heats every time I drive. Damn, I knew I should have went with Toyota OEM
steve miller
10-10-2015 01:40 AM
