Old 02-09-2016, 10:47 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical Guides
Print Wikipost
best plug cap rotor & wire combo for 22re
Old 11-03-2009 | 04:23 AM
robert1965's Avatar
its tune up time. 198,000 miles on the old girl and im wondering what name products do you use together, or should i just go stock. thanks
Old 11-03-2009 | 06:16 AM
Robert m's Avatar
NGK plugs, napa rotor and cap, toyota wires
Old 11-03-2009 | 06:18 AM
JamesD's Avatar
Toyota wires are the best but the cap and rotor can be bought anywhere with just about the same quality as Toyota. If you choose not to get wires from the dealer, get NGK, Belden or Beck Arnley wires. Fuel filter you can get anywhere. Plugs I would go to Autozone since they carry Nippon-Denso spark plugs or they used to. If not use NGK.
James
Old 11-03-2009 | 06:49 AM
DupermanDave's Avatar
Im using autozone wires and cap and rotor. No problems here.
Old 11-03-2009 | 07:56 AM
cgeorge's Avatar
I've always leaned towards stock for the wires. However, I just ordered some NGK wires.
Old 11-03-2009 | 08:36 AM
Teuf's Avatar
NGK all the way i say.
Old 11-03-2009 | 09:11 AM
xxxtreme22r's Avatar
unless running an msd etc, i would think almost anything would work. although I like using and have been on several vehicles including with nitrous the ngk v-powers. Platinum and iridium plugs are overrated i think.
Old 11-03-2009 | 09:18 AM
why NGK over anything else? Does NGK provide better power, or last longer?
Old 11-03-2009 | 10:29 AM
skjos's Avatar
I'd stick with Denso (OEM) or NGK.
I went with NGK components because they were less expensive than ordering OEM parts and they perform just as well (in my exerience).
Old 11-03-2009 | 10:55 AM
DeathCougar's Avatar
In my personal experience, OEM is the best.
Realistically, you are going to get 20 different opinions with 20 different experiences. I see time and again the low quality aftermarket parts fail. For things that can leave me stranded, I trust OEM parts that are designed to go 20 years without failing.
Old 11-03-2009 | 10:59 AM
malteserunner's Avatar
X100. OEM for me.
smthwsn357
05-01-2024 07:28 AM
MO transplant
04-23-2023 11:58 AM
sandyota
02-04-2021 11:16 AM
msane99
07-11-2015 08:08 PM
smiley52
07-11-2015 05:16 AM
Quick Reply: best plug cap rotor & wire combo for 22re
