Beck Arnley tie rod ends
I know OEM is usually best. I want to know your (ie: not what you've heard) experience with Beck Arnley.
I found some Beck Arnley tie rod ends (outers) for $15 locally. Anyone have any experience with Beck Arnley, any horror stories that should make me return them. I was going to do Moog, but the price was more than I could justify at the moment with school fees and books having not too long ago drained my account.
They're supposed to be OEM quality, any bad experiences?
I've never used B/A mechanical parts, but to save a buck I have used a few electronic parts with no issues. So, if that's any sort of testament.
If you got a good warranty, I'd say used them and not worry about it.
The BA TRE's from Autozone have a lifetime warranty. I have a blown boot on one of mine and I bought one of the BA's about a month ago but I haven't gotten around to installing it yet. I like that it had a zerk on it so that this time it won't be overfilled with grease and blow the boot again. If it does break though at least I won't have to pay for it again...
Just enough grease to somewhat "bulge" the boot. Really doesn't need much.
Don't know about B/A's, but the Moogs I got as replacement for the original OEM's have a small seep hole that helps prevent the pressure from building up too high and blowing a boot. And, besides, with the Moogs anyway, if you over grease them, the extra winds up just spooging out of the seals. They're not sealed with a wound, metal band like OEM's.
Not sure about B/A in particular but I blew out a tie rod end and replaced it with whatever the cheap brand it from autozone and it hasn't given be any problems.
I just replaced all 4 tie rods lastnight. I have no experience with b/a. I picked mine up from JC Whitney. They look like they are good quality and they were in-expensive. I put about 2 pumps of grease in mine as it didn't appear to have any grease from the manufacturer.
We don't have JC Whitney local either. I bought mine online. Shipping is free for any order over $75. Not sure if that applies to Canada though.
Some Beck-Arnley tie rod ends are actually circle-555 brand, which is OEM.
If the box says "Made in Japan" then it's OEM.
If it's made elsewhere, it's not a real big deal, B-A parts are good quality.
Now, If I could only get the old one's out. I don't have a puller bug enough to fit over the knuckle.
I tried that. I just came inside to get the maul which is basically an axe with a 12lbs head. Like most axes the back of the head is hammer-like. See if that and the pickle fork knocks it out. I have very little faith in pickle forks.
I honestly don't think anyone has done any part replacements in the last 10yrs at least.
