balljoint's and Idler arm.. what brand???
Old 11-19-2010 | 02:22 PM
gte175x's Avatar
Need help on this too...I was told my problem might be the idler arm but it looks fine - doesn't move when I tug on it...what are the signs of a bad idler arm?
Old 11-19-2010 | 02:35 PM
MudHippy's Avatar
Any play in it. It's not always easy to feel with the suspension loaded. Jack the front passenger side tire off the ground and try jerking on the arm in all directions, back and forth/side to side. If it wiggles at all at the elbow then it needs new bushings. If the tie rod end is too loose then the whole idler arm needs replaced.
Old 11-19-2010 | 03:00 PM
gte175x's Avatar
ok - I'll try. This may be one of my problems... but the actual problem is when I hard lock to the left I get a binding sound and a loud metal to metal pop... I was thinking it was the cv axle, but it looks fine. 4x4 is not engaged (have auto hubs)... could this be the idler? Also, the steering feels sloppy on the highway...
Old 11-19-2010 | 03:10 PM
MudHippy's Avatar
When you have that tire off the ground, grab the top and bottom and push/pull to see if it has any play too. It sounds kinda like loose wheel bearings maybe to me. In that case you'll need to tear the hub apart and repack and retighten them.
Don't assume it's a ball joint untill you've made absolutely sure it's not the wheel bearings. Which it may also be if the bearings are still tight. But that's rarer than the idler arm bushings or the wheel bearings being the cause. Also check all the mounting bolts on the idler arm and steering gearbox. They can come loose sometimes too and cause sloppy steering.
Old 11-19-2010 | 03:29 PM
  #25
gte175x's Avatar
Got it...Thanks - I'm new to this community! Just bought my truck last Saturday!
Old 11-19-2010 | 03:40 PM
  #26
Wheelingnoob's Avatar
Originally Posted by SoCal
I would do Moog also as for the idler arm you can buy 3 Moog's for the price of a TC Arm.
The TC arm is worth it, I went through 3 MOOG's and 4 OEM bushing sets in one summer running BJ spacers and no crank with 33's.
I ended up cutting it all out for that reason and going SAS, should have just got a TC arm.
Old 11-20-2010 | 08:18 PM
  #27
hunter4runner's Avatar
Originally Posted by MudHippy
This unit no good!
thats not a MOOG arm, seemed like you where indicating it was
Old 11-20-2010 | 08:36 PM
  #28
xxxtreme22r's Avatar
oh but I think it is.
http://www.autopartswarehouse.com/sk...n+%26+Steering
and just in case you think it's a generic typo on that site here you go
http://performance.thepartsbin.com/b...1&brandid=4543..
or you can google yourself MOK9424
Old 11-21-2010 | 09:38 PM
  #29
It is not the Moog sold for a 1995 IFS 4runner, http://www.oreillyauto.com/site/c/de...2853&ppt=C0203
it is however the unit sold for older IFS trucks, so I take back what I said, it is a MOOG arm but its not the only option for older trucks but it is the OE replacement. OK sloved that issue
Old 11-21-2010 | 10:50 PM
  #30
pruney81's Avatar
I just put in a Moog in my stock rig and it appears to be much beefier than the shot stock one I had before and it really tightened up my steering.
Old 12-19-2011 | 10:59 AM
  #31
skoti89's Avatar
can those bushings be used with the napa chassis part? http://www.napaonline.com/Catalog/Ca...(P_RecType%3aA)
Also this is a napa import line, I think it is a sankei 555. http://www.napaonline.com/Catalog/Ca...(P_RecType%3aA)
Old 12-19-2011 | 04:12 PM
  #32
96vettelt4's Avatar
Moog...they make a couple different ones...HD have been on with great results...
Old 12-19-2011 | 10:35 PM
  #33
Those napa links posted about don't work so I can't say for sure, but I know one of the NAPA idlers has the thinnest shaft out of all of them.
Do not use a moog idler arm on these trucks, especially the one with the shorter shaft.
The part that the SDORI bushings fit is quite laid out on their site. http://www.sdori.com/SDORI_Theory_Of_Operation.html
In short he only idler arm those bushing support is the Autozone fa5040 / McQuay-Norris FA5040. Not sure if you can still get that McQuay unit at Kragen/orrilies anymore though.
I do not know why people keep asking about the brand of idler they should use. The Autozone one is the best for these trucks. IMO it's better then the OEM one. Especially the OEM ones on the older trucks.
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
Alexdosdall
12-10-2017 05:48 PM
shredder4286
10-01-2015 01:09 PM
tysen86
09-25-2015 11:15 PM
Quick Reply: balljoint's and Idler arm.. what brand???
