Ball Joint spacers safe?
Old 07-26-2006, 10:59 AM
mastacox's Avatar
Thanks dude. Webshots is blocked on my work computer, I'll take a look tonite.
Old 07-26-2006, 11:01 AM
all_terrain17's Avatar
Originally Posted by mastacox
I would inspect before you decide to trim the spacer, I think the outside bolts actually go through an area that would prevent them from working without trimming the control arm, the head or the body of the bolt will get in the way (the "heads" on the OE studs are very flat, to fit in there).
lol, I meant good to hear they're reversible. I wouldn't go through the hassle of machining new parts if it isn't necessary. I'm prob wrong here, but wouldn't the manufacturer make a part that would require as little modification to the vehicle as possible to install? My logic is they would've gone ahead and done it if it meant better sales and less customer support issues blah blah blah...sorry for ranting.
Old 07-26-2006, 11:32 AM
mt_goat's Avatar
Blocked huh, oh I guess you're suppost to be working not looking at pics Ok here's an attachment:
Old 07-26-2006, 11:46 AM
shiftless89's Avatar
Good call...
I'm not really sure why SDORI doesn't do this, one less machining process? You might have to trim INTO one of the holes for the bolts. I'm not sure this would work.
The material you remove from the UCA is trivial and does not weeken the arm, you could even just hammer it back (very difficult to do because of space). I would not trim the spacer as it is designed to be a load/shear bearing device
Old 07-26-2006, 12:13 PM
  #25
mt_goat's Avatar
I agree.
The spacer is just a block of aluminum under mostly compression forces. Being that they are machined out of billet aluminum, they are almost bullet proof for the job at hand IMHO. Now the bolts I could see some significant shear stress on them. The amount of material I removed from my spacers was trivial too, but the stock UCAs are definely different than mine. Just throwing out the idea it may be possible but of course use common sense.
Old 07-26-2006, 12:33 PM
  #26
rollem's Avatar
What about the Downey MEGA Travel Ball Joints? Did they incorporate the spacer in the ball joint or would a spacer be needed with those aswell?
Old 07-26-2006, 01:07 PM
  #27
mastacox's Avatar
yeah well
I like to multi-task
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
4x4YOTA
08-23-2016 09:08 AM
Truckwithoutaname
10-03-2015 03:41 PM
crash813
09-27-2015 07:15 AM
Quick Reply: Ball Joint spacers safe?
