The Ball Joint spacer/Cruiser Coil - Longer Shock P/N thread
#182
BTT
Anyone have the OME shocks on with Cruiser Coils and BJ Spacers? Do they work? Time to order shocks for me - need the correct part numbers - preferably tried by someone!! Anyone?
#183
The ome shocks will fit, but the valving will be messed up so they'll ride bad. I called a guy at ome to try and find a replacement and he said that each shock is valved for the vehicle so using a shock for a heavier vehicle (f100 or lc) on a lighter vehicle (4runner) will result in a crap ride and crappy performance.
#184
Sponsoring Vendor
ps. Praufet, I am trying to get you the diagram you requested along with the other request.
#185
Thanks for you help strap. I decided to for go the omes in favor of the adjustable ranchos cause I was worried about the stiffer valving. I guess it really just all depends on your personal ride preference. It would probably also depend on what mods you have and how much stuff you carry. Crappy was probably not the best word choice. I was just worried the 1000lbs. curb weight difference between the FJ80 and the runner would just make the ride too stiff. Then again I like a pretty soft ride.
Cebby-Are you just gonna replace the shocks? With all your new nifty tools, you might want to think about fabbing new upper shocks mounts. I'd fab some with an upper eye mount to add more shock options.
#186
Originally Posted by Cebby
BTT
Bill
#187
Bill - thanks for the offer, but as you probably know, it is now the cold and flu season - that means my kids have already gotten me sick. I hope it clears up by spring.
#189
Originally Posted by Blizzard
A friend of mine runs with +4cm coils and LC 80 OME shocks. He has a lot of travel and says it's enought strong to run without rear swaybar.
David
David
#191
Hey guys... got my LC Coil lift done... I ended up using... well... here's the list of all the stuff I used (still haven't done the brakeline...:pat: ) :
Long side FZJ80 coils (48321-6A100)
Rancho RSX Shocks: 17027 (Rear) 17079 (Front) I love these!
Marlin Crawler Ext. brake line
Downey 3" Panhard bar drop
1.5" BJ spacers (from TRDparts4u.com)
Aisin Lockout hubs
Also, I only put the BJ spacers on... I haven't cranked my T-bars at all...
Beginning:
Middle:
End:
Aisin Lockout hubs
Beginning:
Middle:
End:
#193
Hey keggo. Looks good. Couple questions. What size tire are those and whats your backspacing? Also did the Downey panhard drop bring it pretty close back to center? Thanks.
#196
Cool... I'd do it today, but I'm not feeling that great. I'm not going to be romping around too much at Pismo this weekend, I think my brakeline should be fine. It still has some slack.
#197
Make sure you use a crow's foot wrench on the brakeline, other wise it will strip.
#199
Thanks Cebby! I don't have any body lift. Just the FZJ80 coils and Bj Spacers. The tires are 33x12.5's. I bought two of the long side FZJ80 coils. I really like the ride with the LC coils. I want to get a different rear bumper... the stocker hangs kinda low... What do you guys think about totally removing the rear bumper until I can get one made? Thanks again, Cebby!
#200
Do you mean a flare nut wrench?
