Ball Joint lube
Old 02-17-2016 | 03:57 PM
grumpin's Avatar
Ball Joint lube
I started getting a very loud and annoying squeak from my front end. Tried to locate it, but was hard to pinpoint. Did a search here and some mentioned Ball Joints. I had lubed the uppers not too long ago, no zerk for the lowers. I remembered the old VW manuals said to jack up the vehicle with no weight on the wheels. I didn't do that, so, today I did. Wow! Big difference. I'm hearing things I hadn't heard before! Didn't realize how noisy it was. I'm sure many people know this and I'm a meathead for not doing it, but, thought I'd throw it out there.
Old 02-17-2016 | 04:57 PM
MudHippy's Avatar
The zerk for the lowers is on the uppers. It just needs put in the right place.
Other than that, I have know idea what you're getting at. Like the point of doing that is? I don't get it. At all. Seriously. W...T...F?
The only part that makes any real sense is VW. In that it totally explains why it doensn't make any sense.
Old 02-17-2016 | 05:16 PM
92ehatch's Avatar
I like the thread title. Got me excited
Old 02-17-2016 | 05:49 PM
highonpottery's Avatar
Aren't OEM Toyota BJs a non-serviceable part? That's why there's no zerk fitting. If mine was dry enough to make noise I'd just spend $35 and replace it with a Sankei 555 BJ that comes with a tapped hole for zerk fitting.
Old 02-17-2016 | 09:37 PM
grumpin's Avatar
I have to agree!
"Aren't OEM Toyota BJs a non-serviceable part? That's why there's no zerk fitting. If mine was dry enough to make noise I'd just spend $35 and replace it with a Sankei 555 BJ that comes with a tapped hole for zerk fitting."
I don't know. My uppers have them, lowers do not. Could be a PO did that.
Old 02-17-2016 | 09:41 PM
grumpin's Avatar
Old 02-20-2016 | 07:48 AM
btu44's Avatar
I replaced my upper and lower IFS ball joints with OEM about 10 years ago. Replace another one recently for a torn boot. They all have had plugs for zerk fittings.
Old 02-20-2016 | 09:34 AM
grumpin's Avatar
Thanks, interesting. I have some records back to 2009 from two PO's. Idler Arms changed and three alignments. No Ball Joints.
Old 02-20-2016 | 11:18 AM
kcaudill's Avatar
Prolly the steering stops making noise. they come with plastic caps, once they wear out the metal to metal creaks starts at full lock
Old 02-20-2016 | 06:09 PM
grumpin's Avatar
Those are good. I put a thin layer of grease on them. It was definitely the upper ball joints. No squeak and overall much quieter.
Old 02-21-2016 | 09:02 AM
edit - never mind solved it
Brandon H.
12-22-2019 12:03 PM
mostmatt
08-26-2016 09:30 AM
natnat5
02-01-2016 12:01 PM
Rattlesnake
01-24-2016 06:01 PM
