Auburn LS up front (IFS)
Old 01-27-2010, 07:36 AM
  #61
Lumpy's Avatar
Looks like you and your rig would have taken a beating on that run.
Old 01-27-2010, 09:03 AM
  #62
AxleIke's Avatar
I'll throw in my .02.
it totally depends on the type of wheeling you do.
I had a LSD in my rear diff, and hated it. It was awesome on road, in the snow. Off road, it was just barely marginally better than open. Most of the time I couldn't tell it was there, which is a bad thing.
I found it to be particuarly lacking with a wheel in the air. My front suspension lifts wheels all the time. If you find yourself lifting wheels a lot, the LSD will do nothing.
However, if you driving in muddy, slick terrain, and need to turn both wheels, I imagine a LSD will do great.
As for CV's, I know auto lockers can play hell on CV's, but throttle is more of an issue. My ARB has saved more CV's than I can count, as it allows my wheels to turn slowly, and always at the same speed. I never find myself bouncing, or slamming wheels down.
Old 01-27-2010, 09:10 AM
  #63
RustBucket's Avatar
Well I like your old truetrac, Ike!
Old 01-27-2010, 11:08 AM
  #64
AxleIke's Avatar
Thats good! Happy that someone got to use it!
Old 01-27-2010, 11:39 AM
  #65
drew303's Avatar
Honestly dont know how much overall performance you'll really gain with IFS and an LSD simply because of how frequent the wheels lift off the ground rendering the LSD useless.
I run Aussie rear and Truetrac upfront but I'm SAS.. and I will say this setup works much better with a Solid axle and flex keeping the wheels touching the ground.
It's just reality there. goodluck!
Old 01-27-2010, 11:41 AM
  #66
rusche's Avatar
I'm running a welded front with 4.88s and 32s. I wheel the piss out of it and have yet to harm a CV. Its all about throttle control.
I say try welding it. See how you like it. Its free, if you dont like it, then take it out and throw in the LSD.
Old 01-27-2010, 12:14 PM
  #67
BigBluePile's Avatar
Actually not a bad thought concidering you have to replace the carrier ANYWAYS!
Old 01-27-2010, 08:43 PM
  #68
rusche's Avatar
Cut it out. Not too difficult.
Old 01-27-2010, 11:02 PM
  #69
drew303's Avatar
Well he said he isn't into any crazy wheeling and sounds like he mostly trail drives.. Welded front is probably the last thing he wants.
My buddy runs welded, no way in hell I could put up with that.
Old 01-29-2010, 06:53 AM
  #70
RustBucket's Avatar
There may be a 4.56 front diff with a lock-rite in our parts collection. Let me know if you're interested in something like that.
Old 01-29-2010, 07:54 AM
  #71
Junkers88's Avatar
Let me know if you happen to have one.
Old 02-19-2010, 10:51 PM
  #72
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Meh... Auburn's a clutch pack and so is the Celica(?) or Celica Supra(?) LSD that one should be able to find at a j/y pretty cheap...
There's also a guy that makes kits for them it the friction disks are wore out...
But we come full circle again... $ for the clutch kit, $ for the LSD at the j/y... And is this worth doing to a 7.5" IFS axle?
Why not buy a geared LSD and be done with it? No special fluids, and no going back in b/c of worn out friction discs.
Originally Posted by corax
My 4runner with an '83 Celica Supra (5mge) LSD up front works fine in the snow and ice . . . I haven't had any twitchy handling or scary moments yet and I drive like a -tard
Here's the thread I found most helpful when I first started considering this
The *official* 7.5" Supra LSD into a IFS diff thread
. . . and my post on the install
the only problem I had with the install was trying to find shims so I could set carrier bearing preload and backlash -- luckily I was able to mix and match between the Celica Supra carrier shims and the original 4runner shims
Old 02-21-2010, 08:12 AM
  #73
dfarr67's Avatar
Whats the best price anybody has seen for a trutrac? for the ifs is the a 4 cyl vs v6 model as well- like the rear diff? I'm looking for the 4 cyl I suppose.
Flying91
45
04-11-2024 04:39 PM
88sasturbotoy
08-11-2015 01:56 AM
deepmarsh
08-06-2015 03:44 AM
coffey50
07-28-2015 10:55 AM
scottyg486
07-19-2015 05:34 PM
Quick Reply: Auburn LS up front (IFS)
