ATF leaking from bellhousing
what does this mean? transmission shifts like normal, but there's a slow drip from the seam where the bellhousing bolts to the block, down onto the diff, then onto the ground. it's making quite a mess
119k on the A340H tranny
Probably the front seal on the tranny is leaking. Check the fluid level more frequently. A small drip is just messy but if it gets worse it should be replaced.
atf leak
Good luck!
In retrospect I was in a hurry to get my engine installed and went with the Oreilly seal. Looking back I would be more comfortable if I had purchased an genuine Toy seal.
Sorry about the supersize pic everyone.
yourrealdad
07-29-2015 11:08 AM
1994, 4runner, 99, a340h, atf, belhousing, bell, bellhousing, dripping, housing, leak, leaking, oil, transmission, yotatech
