Ams vs regular vs synthetic oil
I ran Rotella in my 3.5L Trooper for a few years but I have the dodgy oil rings that cause the engine to use oil so I switched back to dino.
http://www.lubedealer.com/dbcox/images/KnowTheFacts.gif
In the link above, notice that the yearly mileage savings is calculated on 25,000 miles per year, with normal driving 12,000 to 15,000 per year, so I typical user would not experience such a large savings. With the lower threshold of 12,500 it would work out to be about $88 dollars per year for regular dino, and with only one oil change per year with amsoil, you would save around $20 bucks a year and some time under the vehicle.
I respectfully decline to answer that question.
... as it bears no relevance to the topic de jour.
Guns don't kill people... people who point a loaded gun at people, then proceed to pull the trigger are what kills people.
Who should have a gun? The person who would ask someone to "leave" or the person who would ask "give"?
NOTE: I doubt Amsoil guarantees the extended drain interval. I would ABSOLUTELY NOT take anyone's word that you could go 15k miles or 1 year without changing it without a Used Oil Analysis.
#25
I run mine 25k in more than 1 vehicle i dont care what the driving conditions are. I get my vehicles tested and I run 25k. My 4runner hasnt made it to that point yet but its on its way i have only had it a year. I swaped it when i got it and ran the XL line 12k and tested it it came back god and o internal issues. UOAs is the only way to know if its working. Oneday all the brainwashed 3k oil changers will be people of the past I cant convince everyone but i put it out there. My wife drives one of the vehicles and she drives the living hell out of a car, it holds up to 25k no problem. I have a truck that sits in the garage most of the time I do it once a year no problems.
If you drive like 2 miles to work a day it may be diferent thats the worst on the oil.
#26
I'm using Amsoil 15W50 right now, but I haven't noticed too much difference between that and the Mobile 10W30 synthetic I had before. Oil pressure is a little higher at idle. I think I will switch back to a Mobile synthetic next time. I like to change the oil more than once every two years or what ever Amsoil says is ok..
'm using ... 15W50 right now
SPECIFICALLY why ?
There is no reason to use anything "thicker" than 0w-xx or 5w-xx (if you can't find a 0w-xx) and lots of reason not to.
Also, again, the vast majority should be using nothing "thicker" than 0w30 or 5w30 and most can probably use a 20 weight even.
15w50 is waaayyyyyy to thick for anyplace that you'll ever drive.
Why in blazes are you using that ?
You went from a 10w30 to a 15w50 and you seem a little surprised that your oil pressure is higher. You should be shocked if it wasn't.
Fred
#28
This may not be the answer you're looking for but the owners manual recommends oils from 5W-30 up to 20W-50 depending on the temperature range that you drive in. Where I live it recommends either 10W-40 or 20W-40 for the summer.
#29
Kinda silly IMO
Move out of the cave, learn to start a fire without the help of lightening and enter the modern era
Fred
nframe
3.4 Swaps
08-16-2015 09:03 AM
