Alternator Wire replacement problems.
#41
OK, Yeah, you got 2.1 ohms to ground so definitely a bad alternator.
Good decision. When you get it, double-check using same method above. You should get very high resistance from copper bolt to alt body.
Then, when you re-install alt, verify the voltage readings at various pins I outline on my post linked above.
To upgrade someday, in case you haven't found it yet, there's a Jaguar Alt upgrade.
Electrically plug n play, Mechanically just need to swap pulley with stock pulley AND slight bending of mount bracket.
Best of luck.
Best of luck.
#42
Best of luck.
Best of luck.
I will check it rigorously.
I do like the look of that jag alt and i was going to do it but i want to get a second bracket to bend so i can always slap a stock one back in. Also i don't have the impact wrench necessary to change the pulleys.
Thanks again to everyone who weighed in, i appreciate it.
steve miller
10-10-2015 01:40 AM
TURBOrunnerNM
07-22-2015 11:01 AM
