After replacing transmission tail shaft bushing truck will not go in gear.
Good day to one and all, hoping all is well in these times.
I have a question, hoping few can Help, Thanks. I have a 91 toyota pickup 2 wheel drive
and have just replace the tail shaft bushing. The Problem is, transmission will
not go in gear after reinstalling tail shaft housing and shifter. truck was in neutral before removing tail shaft. Can not go in any gears, it is stuck.
Tranny oil did not make any difference. The tail shaft spline turns only when the clutch is depressed. Help thanks.
