accidentally hit the clutch start cancel button now wont start up after off
#42
on the other hand...
the top bolt is a stud, not a bolt. pull the starter out and green loctite that thing in.
it'll save you a lot of wrist and finger cramps later on when you have to pull the starter again.
#43
apparently when you hit the CSC button the upper starter bolt flies off and the starter falls half way out of the bell housing. Problem solved. I could have rocked it until my nipples were filled with gallons of milk and it still wouldnt have done anything. I will put the top bolt on and should have it back in action.
#44
Location: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
oh it most certainly did. You were right, I meant the top NUT. I was like, what in the hell, that clutch start cancel button is now removed from the vehicle and digarded in the proper manner. I am afraid if I twist my dimmer button my tires might explode.
#46
same, i put in an automatic starter and i wired it so i dont even need to push down my clutch or even hit the clutch start cancel button.. i took the whole thing out and put my kc lightswitch there instead =)
#50
That is the sound that my dad's starter made when it had a flat spot in the starter motor. we thought it had a dead battery at first so we went to jump it and it drew both of the cars down. we took the starter off and it had arc welded the winding to outside of the starter.
#51
#52
#53
you shouldnt have to hold the clutch start button down just push it once, and once you push it it will stay lit until you shut the truck off, now for it not starting I dont think it has to do with the csc button because the clutch will over ride it when you push it in. Im thinkin if you here here a winding noise its your starter and it froze up. ive had it happen on one of my other yotas try tapping on your starter with a hammer, sometimes it works
#54
#56
agreed 91toyota, anyone ever sit down and enjoy a nice 30 pak of Keystones? Any one getting "STONED" off some keystones besides me in Cincinnati?
