Ac 1991 toyota 3.0
Old 08-04-2023 | 05:21 PM
Jpl00311's Avatar
Ac 1991 toyota 3.0
My ac gets hot at idle. Can someone show and tell me about components in sc idle up system.
Old 08-04-2023 | 05:25 PM
Jpl00311's Avatar
Ac
I deleted the egr just wondering if I took out to much.
Old 08-04-2023 | 05:30 PM
Discombobulated's Avatar
Was it working before your delete?
The following users liked this post:
Jpl00311 (08-04-2023)
Old 08-04-2023 | 08:21 PM
Jpl00311's Avatar
Ac didn't work at all before delete. Had a broke wire on compressor I had to fix.
Old 08-05-2023 | 01:05 PM
Jimkola's Avatar
YT Community Team
so, your A/C didn't work because of broken wire.
you fixed wire and A/C worked fine.
you then deleted EGR and A/c quit being fine.
I'm saying yes, something important to A/C got removed or unplugged.
A parts schematic, like at EPC-data.com should offer some help to the ac system
Old 08-06-2023 | 09:12 AM
Jpl00311's Avatar
Ac works fine when truck is moving. Gets hot when I stop at red-light stop signs etc.
Old 08-06-2023 | 11:06 AM
JoeS's Avatar
Check the fan operation. Is it an electric or clutch operated fan. If electric, you may have disconnected/broke a plug/wire in your AC fix and EGR rip-out process. Could not have enough air moving across the AC condenser at idle. If the fan is running with AC on at idle them that's an easy check off on the list of potential causes.
Hairyberry (08-07-2023)
Rithsleeper
07-30-2019 02:03 AM
YODAIII
02-21-2011 10:03 AM
highway
02-24-2007 05:49 PM
Quick Reply: Ac 1991 toyota 3.0
