95 4x4 4Runner 5 speed swap
Was just wondering what other parts do I need to complete the swap so far I have the trans, pedal assembly, master, clutch slave, ecu, flywheel, clutch, rear shaft so far any help will be greatly appreciated.
This is one of those things not having the donor vehicle close at hand is a real pain!!
We all forget something
New flywheel bolts ??
The transfer case and new mount
The cross member !!
The means to make a new line for the clutch Hydraulic system plus the rubber line.
I hope your going with all new parts Aisin if possible the other stuff is pure junk as of late.
The shifter boots and covers
The electrical end getting around the neutral safety switch
Like I said a bunch more nickle and dime things causing numerous trips to the auto parts stores and other sources for parts .
Good luck!!!
The cross member !!
Good luck!!!
This is one of those things not having the donor vehicle close at hand is a real pain!! We all forget something New flywheel bolts ?? The transfer case and new mount The cross member !! The means to make a new line for the clutch Hydraulic system plus the rubber line. I hope your going with all new parts Aisin if possible the other stuff is pure junk as of late. The shifter boots and covers The electrical end getting around the neutral safety switch Like I said a bunch more nickle and dime things causing numerous trips to the auto parts stores and other sources for parts . Good luck!!!
FS[PacNorWest]: Parting 2000 4Runner Limited 4WD Marysville, WA
DeathCougar
04-02-2018 12:29 AM
Shaun Crystal Gomban
07-30-2015 11:13 PM
