95 3.0 only running on 3 cyllinders
read thru this carefully.
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
here is the section on how to test the afm.
http://personal.utulsa.edu/~nathan-b...92volumeai.pdf
I think you have an injector problem personally. either clogged or a wiring issue related to the injectors. good luck
WOW just got the 1 and 3 injectors out. Clogged is an understatement. Loads of junk like a fine silt and chunks. I guess I'll blow the lines out and vat the fuel rails and drop the tank and check it out. And will probly go ahead and buy a new set of injectors. Any thought on the upgrade injectors on eBay? I post the link. Also could this be a cause of my knock. (Was mainly on passenger side)
http://m.ebay.com/itm/261146725006?nav=SEARCH&sbk=1
XtraCab
04-12-2020 05:25 AM
