94 pouring out white smoke
Try the power steering idle up valve man, its super easy to pull the hoses off the the bottom of the valve on the side of the pump, and if fluid is pouring out thats the problem...I hope.
Good luck.
Good luck.
ya i'm going to mention this to my son and have him look into it , also should correct myself the plenum is what he pulled off.
here are some vids on bluedevil and steelseal and thermagasket; these are the only ones
I recommend; they are a bit pricey, but they work.
http://www.youtube.com/watch?v=3suQy44G_B0&feature=fvw
http://www.youtube.com/watch?v=skKwZ...eature=related
now then, if you have old radiator / pump parts that are moslty clogged up , or have really small holes by now, I would hesitate to use these products.
Even though they are supposed to work on a heating/thermal/steam exchange area, I don't know if i would trust them to not close up small areas elsewhere.
charlie_fong
09-27-2015 10:06 PM
