94 Pickup Rotor Question
i used to do the hammer thing, then i went to a fine tipped flat screwdriver inserted into the slot of the cone washer. a light tap with a hammer and they come right out, usually gripping the screwdriver blade.
a punch applied directly to the end of the studs will dislodge them as well. remember, a bit of antisieze and finesse will go a long way.
lee
lee
exactly - they're designed to be removed by expanding that gap. complaining that they're hard to get out without doing that is like complaining that you can't torque a head bolt with a rock.
Hey Issac,
I said I got it. None of you wise acres came up with that little gem untill after I stated that I got them out. (BTW, I tried that and all I accomplished was jacking up the washers. The spark plug socket worked like a charm.)
Props to TNRabbit who sparked my memory of using the old mashed up socket on the pickup a couple of years ago.
Sooo, attempting to look like a smart guy now is like showing up to help a friend move a week after he has settled into his new digs.
But thanks for the idea, Next time I'll try a rock.
#26
haha. i really only posted about the cone washers for the benefit of anyone referencing this in the future. glad yours came out ok, i've heard some real horror stories..
hope you antisiezed them when you put them back in, though!
TURBOrunnerNM
07-22-2015 11:01 AM
