94 pickup RAIN electrical short
Old 01-10-2020, 04:07 PM
Co_94_PU's Avatar
Iirc "clicking in the right hand side of the dash" presummed to be a relay, and a "five amp draw" showing on the meter..
For S&G's, have someone push open the flaper/vane in your air meter while you sit in the cabin...
Your circuit opening relay is down there, and a fuel pump draws about 5-7 amps after it spikes.
That 1.9 your seeing is the voltage drop across the diode fwiw..
Carry on.
Old 01-10-2020, 06:09 PM
RAD4Runner's Avatar
Originally Posted by jdfnnl
.... A resistance test between the 10mm post on the alternator and the frame stays at 1 except on the continuity setting, which stabilizes at 1.9.
1-ohm? That's low! Tested with alt-to-batt wire disconnected?
Old 01-10-2020, 06:59 PM
jdfnnl's Avatar
not sure what the units are on the continuity setting .. but all the other resistance settings had a reading of 1 -- not sure what anything > 1 means as it's my understanding anything ≥ 1 is an open circuit.
Old 01-11-2020, 04:01 PM
Co_94_PU's Avatar
That is definitely a diode test mode.
I've got a alternator sitting here, not sure its fully assembled (yep no brushes or regulator attached YMMV), let me find my meter..
The following users liked this post:
jbtvt (01-11-2020)
jdfnnl
01-03-2020 08:30 PM
J's-88
07-27-2014 11:14 AM
1986YotaBeast
09-30-2013 03:15 PM
hill
09-05-2005 08:08 AM
scott.475
11-12-2004 04:10 PM
Quick Reply: 94 pickup RAIN electrical short
