93 third member on an 86
It's a 2wd then it's more than likely spring under, so that would need to be changed. Also being a 7.5" I believe it's 27 spline - so you couldn't change the axleshafts to keep the 6 bolt (31 spline), you would end up with 6bolt front and 5 bolt rear - so in short no!
the search continues...
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
