93 22re conversion to 22ret
Hey, I've got a 93 truck with a 22re I rebuilt. I saw someone selling all the parts of the turbo set up from an 86 22ret. I looked a bit with no prevail. Anyone know if it's a decently simply add-on?
I'm mainly concerned about swapping wiring harnesses and ecu's? His comes with at least the ecu, not sure about wiring harness. But idk if it would be a mess converting.
here is some reading material
"site:yotatech.com 22re 22ret conversion wiring"
https://www.yotatech.com/forums/f116...e-22re-243825/
https://www.yotatech.com/forums/f116...arness-180235/
And this one outta keep you busy for awhile
https://www.yotatech.com/forums/f120/22ret-swap-260681/
And the Wiring diagrams can be found here. Just in case your head is not already on fire.
http://www.22rte-trucks.com/simplema...php?topic=91.0
Really alot of work for little gain.
Just watch these exhaust manifolds have a tendency to crack so if your going to do this look at parts in person before reaching for the wallet.
Also be aware that all the intake piping is obsolete from Toyota so figure on sourcing your own.
r3dfish
54
05-16-2016 10:31 PM
Jcrawl94
10
10-24-2015 04:34 PM
priest16
15
08-06-2015 07:43 AM
