92 TOY's 22re / crapped out / gotta start somewhere / thread
#1661
so, on today's episode:
I plan on cleaning up the rocker assembly and those corresponding holes on the intake side of the head so that the assembly matches up with less effort..
i will loosen up those set screws to get it to sit better too.
I'm going to have to buy a set of feeler gauges to get the rockers to sit near correct even though i know i really have to adjust them when the engine is at operating temp.
that part rattles me....I hate the idea of taking off that valve cover once I have it on....it's a total PITA .......maybe I will search BLEEDER's pics (bows head in memory of his truck) to see what he did to eliminate all that crap on top of the cover.
#1662
Doing it warm is not all that bad. You just have to take the vac plate off the top and pull the cover. Not a lot to it.
#1664
just took the cam out and put it back in again.....had used oil on it but then thought i ought to use my assembly lube i had...so that's what i did.....so there.
#1666
Every time I go to read this I see
Well after I get something to eat...So you eat after every part you put on or take off???
I think I've gained weight since you started this project. In fact I know I have
#1671
hahahhahaha...like a sympathy pregnancy....hahahahaha
and for the record, i did NOT eat yet.....I was out in the garage....
pics to follow.
#1672
and this is last night's finish...which I undid this morning to apply the lube...
and the rocker assembly
and here we are now
and here we are now
#1674
Now...
the 2 buggers I have circled in red are backed out a HORRIFYING amount!! But upon further review I see that they both are at or near the apex of their cam lobes....(stop to allow the chill from my vast understanding to fade)....and I understand why the were so tight, and I also understand why I had to loosen them to get that assembly one.....it's like an epiphany.........
#1675
Umm, I am at work, and I just saw some nice pics.
I guess county Gov't. is different from Gov't. gov't. hehehe I'll take it.
I'm just sayin' Logan, just sayin'
#1678
If you want to see the pretty pictures you should use your computer to remote to your home computer to look at YotaTech pictures... Not that I'm telling you how to circumvent the system.
