92 TOY's 22re / crapped out / gotta start somewhere / thread
Old 03-30-2010, 01:19 PM
  #1641
92 TOY's Avatar
Originally Posted by flyingbrass
By rail, do you mean the rocker assembly? Mine was hard to pry off. Loosening all the rocker adjusting screws first would have probably made it easier, but I didn't think of that at the time. I left the screws backed out all the way when I put it back on.
Originally Posted by Lumpy
Oooo ya I forgot about having to loosen the adjusting screws on the rockers... Oops well you got it anyway. Just be sure to have them loosened when you go and put it back together or you will not get a good reading on the head bolts when you torque them down.
Originally Posted by yotarob2005
I did the exact same thing, had to fight it to come off, then backed off the rocker adjustment when I put it back on.
This was the stuff.....you guys don't mean the 3 rails on the assembly...right?
you all mean the nut / screw combo above the valves...right?
Old 03-30-2010, 03:03 PM
  #1642
Lumpy's Avatar
That is correct the adjusting screws on the rocker arms need to be loosened up prior to installing the head.
Old 03-30-2010, 03:18 PM
  #1643
92 TOY's Avatar
k-thanks
Old 03-30-2010, 03:20 PM
  #1644
Lumpy's Avatar
Not a problem...You're going to have that thing running real soon man I can't wait to see it run!!!
Old 03-30-2010, 03:28 PM
  #1645
92 TOY's Avatar
wife sitting right next to me right now...........
yes, soon.
Old 03-30-2010, 03:31 PM
  #1646
Lumpy's Avatar
Alright I'll have to behave then...
Old 03-30-2010, 03:39 PM
  #1647
92 TOY's Avatar
she went away....."why are you typing that???"
Old 03-30-2010, 03:42 PM
  #1648
92 TOY's Avatar
see if you have any recollection of this little piece.....
on the rocker assembly, on the intake side, each "leg" that a head bolt goes through has a round barrel-like attachment....but not the exhaust side. I don't see any mention of it in the books or any of the exploded views of the parts......
those "barrels"....are the things that made it tough to get this thing to seat the right way when i put it together 2 weeks ago
Old 03-30-2010, 03:43 PM
  #1649
92 TOY's Avatar
i'll snap a pic
Old 03-30-2010, 03:47 PM
  #1650
92 TOY's Avatar
just decorated a prior pic.....the ones you don't see are still inside the rocker assembly
Old 03-30-2010, 04:16 PM
  #1651
yotarob2005's Avatar
those are to properly align the rocker assembly with the head, they are ment to be a tight fit. They should go back on fairly easilly you may have to give them a few SOFT blows with a dead blow hammer. Like it was said before, just be sure that the valve adjusters are backed off & the rockers are loose.
Old 03-30-2010, 05:06 PM
  #1652
92 TOY's Avatar
going to work on all that tomorrow....thanks.
I cleaned up the cam all nice and the bearing caps (or whatever they are called) and put the cam back......14ft/lb just like the FSM called for...and yes I oiled it all up 1st.
Old 03-30-2010, 05:29 PM
  #1653
Lumpy's Avatar
You be right...They are also there, in my belief, so that you don't put things together backwards as well.
I was gone for a bit...had to do a Jeep recovery at the mall this evening. Luckily I think it was just the battery. But it took almost 2 hours of my evening.
Old 03-30-2010, 05:48 PM
  #1654
92 TOY's Avatar
youch.....hope you're right about the battery.
Old 03-30-2010, 05:58 PM
  #1655
Lumpy's Avatar
ya messed with if for a bit with another truck (father-in-law) charging it. I cleanup the neg terminal and drove it home. Going to have a look at it and probably change the battery. Just another $80 I didn't plan on spending this week. -sigh- I guess Ted is going to have to wait a bit longer till I place an order.
Old 03-31-2010, 01:46 AM
  #1656
92 TOY's Avatar
I'll tell ya, your life sounds like my life....sheesh!
Old 03-31-2010, 01:54 AM
  #1657
totally a bro
Staff
vital22re's Avatar
morning jerry! build is looking good!
Old 03-31-2010, 01:58 AM
  #1658
92 TOY's Avatar
back at ya....and thanks.
was just out there eyeing up what I should do today. head is almost complete, have to put the rocker assembly back on and clean up any residue top and bottom of it and clean intake and exhaust gasket areas and the I'm good to go.
Supercharger party coming up I see, eh?
Old 03-31-2010, 01:59 AM
  #1659
totally a bro
Staff
vital22re's Avatar
yeah.. im 500 bucks or so short of one wheel wonder glory!
Old 03-31-2010, 02:02 AM
  #1660
92 TOY's Avatar
I hear ya......if I could just have ONE paycheck that wasn't already accounted for, life would be sooooo much better.
Quick Reply: 92 TOY's 22re / crapped out / gotta start somewhere / thread
