92 TOY's 22re / crapped out / gotta start somewhere / thread
Old 03-25-2010, 11:55 AM
  #1541
Lumpy's Avatar
I just readjusted the valves I didn't replace the screws and the old nuts work just fine.
Old 03-25-2010, 12:51 PM
  #1542
xxxtreme22r's Avatar
when I did my rebuild Todd had mentioned if you can see the hourglass shaped markings on the screws to replace them and only with dealer parts not aftermarket. I opted to do that and replace the nuts as well. cheap insurance for the new head/valves and cam. In retro spec I wish I had bought a whole new rocker assembly including the upgraded oiling style shafts.
Old 03-25-2010, 02:27 PM
  #1543
92 TOY's Avatar
done for today....
Old 03-25-2010, 02:31 PM
  #1544
flyingbrass's Avatar
I replaced my screws. Ditto on wishing for a whole new rocker assembly, but they are pricey. I think Putney's was selling them for around $200. That was reconditioned Toyota rockers and the upgraded shafts.
Here's the wear pattern on an old screw.
Old 03-25-2010, 02:32 PM
  #1545
toyospearo's Avatar
WOW that thing is gorgeous!!
Old 03-25-2010, 02:39 PM
  #1546
yotarob2005's Avatar
Originally Posted by 92 TOY
done for today....
Looking good Buddy!
Old 03-25-2010, 02:48 PM
  #1547
Pumpkinyota's Avatar
question on the valve cleaning thing.......
1 valve at a time eh?? or do I take them all out and clean everything and them put them back. I'm guess either way is fine, just have to keep one million parts in order.
suggestions .......
Oh and a shopping list.....
valve spring compressor thingamajig..
magnet thingy
very small bottle brush thing for cleaning the passages (see i was reading the FSM)
One valve at a time, for ease of rememberance. YAY!!!!
Old 03-25-2010, 02:50 PM
  #1548
Originally Posted by yotarob2005
Save your 50 bucks because even if you did buy new ones you would still have to lap them for the sake of the valve seats matching the new valves just right.
Actually... you would have to have them cut and seated, not just lap them. That would be a machine shop job, around 250$...
Old 03-25-2010, 02:57 PM
  #1549
92 TOY's Avatar
Ok , so consensus is keep the valves, don't get new ones but DO get new screws??
Old 03-25-2010, 02:59 PM
  #1550
92 TOY's Avatar
thanks for the compliments guys.
did anyone see the head bolt wedge job?(hiding at the driver's side guide)
on the 2 water tubes that are on either side of the top of the timing cover, do you use a gasket there?
the timing cover gasket was actually itself a gasket for those....I'm just wondering if there was or is supposed to be anything else there.
Old 03-25-2010, 03:01 PM
  #1551
92 TOY's Avatar
10mm bolts (not head size) are 29ft/lbs
8mm bolts are 9 ft/lbs
the passenger's side water tube I used 9 ft/lbs on as well.
Old 03-25-2010, 04:31 PM
  #1552
Csbauer's Avatar
Love the look its almost over just think of that!
Old 03-25-2010, 04:49 PM
  #1553
92 TOY's Avatar
thanks man.
yeas, i'm at the point where I am reading and re-reading everything, hoping and praying not to have to un-do or re-do anything.
currently i'm worried about placing the head on and not being able to get the chain on it.....guess i'll have to wait and see/
Old 03-25-2010, 05:00 PM
  #1554
92 TOY's Avatar
I'm not finding that stuff on the dealer site.
where did you get your's from?
Old 03-25-2010, 05:24 PM
  #1555
Csbauer's Avatar
Yea but at least you have torn through it and have seen all the pieces fall apart. So if anything it should be a matter of looking at the pizza boxes and going slow to read and remember what each note means. Its straight forward! and just think, you get to drive it soon!
Old 03-25-2010, 05:51 PM
  #1556
I don't know if you really need new adjusting screws. I used a new head and wanted fresh ones to ride against the new valves.
Adjusting screws are 90913-05019. I got mine from 1sttoyotaparts, but they may be cheaper elsewhere if that's all you're ordering. Shipping is 10% of the order cost or $10 minimum.
I reused my old nuts, but if you want new: 90179-08049.
Old 03-25-2010, 05:56 PM
  #1557
92 TOY's Avatar
thanks CS..
Flying...thanks for the part #'s...we will see.
Old 03-25-2010, 08:12 PM
  #1558
Staff
Terrys87's Avatar
92 Toy, I was reading rogermans rebuild and noticed you helped him out quite a bit. You come along way, I remember when you started on yours. Hang in there.
Old 03-25-2010, 09:43 PM
  #1559
BINGO...
that's the part that has had me sick since last week. when I "pryed" it off and then put it back together, it did not seat flush again....half of my brain thought the head bolts would snug it down, the other half thought it would falsify a torque reading....so in that respect, I am glad i will be doing this little "side project"....how many of those have there been?????
Are you planning to take the rocker assembly apart and clean it out? If so, buy an impact driver. I bought one at Autozone for $10. IIRC, a #3 Phillips bit is the one needed to take out the 3 screws. Also, give the screws a decent smack to tighten when putting it back together. Here's a video from Putney's: http://www.youtube.com/user/putneysc...12/9Yr3-iBAtf8
Keep everything in order. Put it all back the way it was.
Check out Putney's other videos. I see they have added more since I last checked. The ring and piston installation ones almost made me sick. What that guy did in a few minutes took me hours. But, a big part of doing projects ourselves is to learn. Crawl, walk, run...
Old 03-26-2010, 05:52 AM
  #1560
Lumpy's Avatar
I saw that timing cover on and installed and it brought a little tear to me eye. Well done!!!
Quick Reply: 92 TOY's 22re / crapped out / gotta start somewhere / thread
