92 TOY's 22re / crapped out / gotta start somewhere / thread
Old 03-18-2010, 01:41 PM
  #1361
92 TOY's Avatar
Originally Posted by xxxtreme22r
I used just gaskets on the timing cover, dry head gasket except for there the timing cover meets up in the corners. Use the gaskets for the timing cover from the headset not the one in the timing chain box.
OK ...DRY.
I didn't even open the gasket container yet all shrink wrapped laying there..hahahah
Old 03-18-2010, 01:47 PM
  #1362
92 TOY's Avatar
Ok.
Old and new
YIKES!!!!!!!!
DOUBLE YIKES!!!!!!
Old 03-18-2010, 01:53 PM
  #1363
92 TOY's Avatar
TEASER>>>>>>>>>>>>>>>>>>
Old 03-18-2010, 02:29 PM
  #1364
Lumpy's Avatar
Now that makes me happy!!! Way to go man. Now that looks purdy
I did my HG dry, I didn't add anything to it.
Old 03-18-2010, 02:40 PM
  #1365
Irish Death's Avatar
nice lookin engine there!
Old 03-18-2010, 03:24 PM
  #1366
92 TOY's Avatar
thanks .......done for today though...I painted an EGR tube and the vacuum manifold so they will be ready.
work tomorrow.
thank you very much...of course, I took that right back off....ran out of time to do it right.
Old 03-18-2010, 03:42 PM
  #1367
Magnusian's Avatar
Location: Downtown Heckronto, Ontario, Soviet Canuckistan
How much of a horsepower gain are you expecting from the tie-wrap mod?
Old 03-18-2010, 03:53 PM
  #1368
92 TOY's Avatar
10.
that's a pain in the nuts to try to hold here and there and this and that at the same time.........taping off the tensioner almost worked for like a minute but the spring is quite strong for masking tape.
was re-reading the FSM....looks like I'm doing it right. will re-read Roger's (4Crawler's) write-up to compare notes.
Old 03-18-2010, 03:54 PM
  #1369
92 TOY's Avatar
POSTED THIS ON YOTAROB's thread................
back to business...
as far as the water pump install goes....pretty much straight forward...3 studs that you thread in to the holes....I used the same configuration as my old one...except had trouble figuring this out because there's a short end and a long end to the stud and either way they don't stick far enough out of the water pump housing to get a bite....so I short threaded them so they would stick out. was able to torque down (69 in/lbs...kinda alot if you ask me) and ended up spinning a stud out....took the threads and all with it...so I exchanged holes with a bolt and all was well...hope this doesn't turn into a problem for me...but if it does I know which one it is.
I will email Ted and tell him maybe need longer studs........Otherwise it was all good.
everybody seems to be telling me to use the gaskets dry. the water pump I put blue rtv on it....i guess i didn't have to...don't see anywhere that i had to do that but i did it anyway.
half a mind to put the cover on now, but I will wait until saturday (work all day tomorrow).
Old 03-18-2010, 06:15 PM
  #1370
flyingbrass's Avatar
Wow, lots of progress today. Looking good.
I did a lot of searching and found differing recommendations about the water pump gasket. Installing dry has a following. Some have had leaks after using RTV, probably from using too much. Others have had good luck using a thin skim coat. I used High Tack spray on both sides of mine.
I wiped a thin skim coat of gray RTV all over my timing cover gaskets, but regretted it almost immediately. Messy, and maybe even counterproductive. We'll see. I wouldn't do that again. Maybe just a little around the water passages. Or maybe just some High Tack.
Don't use any sealant on your head gasket to block junction. Put some tiny dabs on the timing cover where the manual shows.
Opinions also seem to differ on what, if anything, to use on the intake gasket. Couldn't find very much info about that. I ended up using a Fel-Pro that had a pre-applied bead of sealant. What do others use?
My water pump from Engnbldr came with 4 new studs for the fan clutch, but not the 3 studs that (along with the other bolts) hold the pump to the timing cover. If you're confusing the fan clutch studs for the pump studs that could explain why they are too short. I reused the ones from my old timing cover.
Old 03-18-2010, 06:30 PM
  #1371
yotarob2005's Avatar
to FLYINGBRASS.
And good progress 92 TOY.
Did you have a gasket for the timing chain tensioner?
Old 03-19-2010, 01:41 AM
  #1372
92 TOY's Avatar
whoa...............Ok flying, I see what you mean............F!
hopefully I can reuse the ones from the clutch......dang!
Old 03-19-2010, 04:33 AM
  #1373
I agree that most people use too much RTV and that is prob what causes most leaks, I am planning to use a very small amount on the timing cover & water pump, none on the intake. The first set of intake gaskets I bought from Napa had the pre-applied bead of silicone but I am not sure about the set I'm using this time from ENGNBLDR, I haven't opened them yet.
Old 03-19-2010, 11:03 AM
  #1374
Pumpkinyota's Avatar
Originally Posted by 92 TOY
Ok.
DOUBLE YIKES!!!!!!
Hmmm, I was looking at this, and I didn't see any matchmarks on the timing chain. These would normally be shiny silver links, there should be two silver links on the cam sprocket side, and a single silver link on the crank sprocket side. Am I just missing these in the pic, or are they on the backside?
Old 03-19-2010, 11:13 AM
  #1375
Lumpy's Avatar
Probably on the other side of the chain.
Old 03-19-2010, 12:05 PM
  #1376
[insert random "backside" joke here]
Old 03-19-2010, 03:56 PM
  #1377
92 TOY's Avatar
shudddup.
they are there. there just are camera shy......trust me they are there
Old 03-19-2010, 04:13 PM
  #1378
Magnusian's Avatar
The old quick switch-a-roo, eh?
Old 03-19-2010, 04:17 PM
  #1379
92 TOY's Avatar
not quite.
just got home from work.
Old 03-19-2010, 05:49 PM
  #1380
Lumpy's Avatar
Kinda figured they were there just had to bust on ya a bit.
Quick Reply: 92 TOY's 22re / crapped out / gotta start somewhere / thread
