92 TOY's 22re / crapped out / gotta start somewhere / thread
Old 11-20-2009, 05:19 AM
  #681
92 TOY's Avatar
Originally Posted by xxxtreme22r
Your gonna regret dropping that Diff, I did, as for the oil pan gasket, if you were to take the bolts out, the pan drops enough to get the gasket off and place a new one on. The cross member is also a PITA to get back in. and if not lined up properly, can affect alignment.
I'f I come down there. I'll have that thing out in less than 20 minutes
I don't want to be regretting anything.
I know I'm getting flamed for being obsessive about this, but that's OK with me.
still reading.............
Old 11-20-2009, 05:54 AM
  #682
92 TOY's Avatar
OK.
Looks like I could remove this bolt rather easily....
These are the motor mounts? Right?.......Not touching, just asking.
Why does it look like this stuff will get crushed if I raise the engine?? I now I'm only supposed to raise it less than an inch as per the FSM, but........
Old 11-20-2009, 05:56 AM
  #683
92 TOY's Avatar
xxxtreme22r...
I can't see how raising it an inch is going to provide me clearance to do anything....and by the looks of it I have just barely more than an inch to raise it.
Old 11-20-2009, 05:59 AM
  #684
92 TOY's Avatar
when I jack up the truck, should I put jack stands under the frame at about the leading edge of the doors or where should I put them???
Old 11-20-2009, 06:04 AM
  #685
Lumpy's Avatar
Wink
You have an auto so there are more wires heading to the tranny than us with the 5spd.
1. Take all the bolts out
2. Unbolt the oil pickup (worry about getting it in later) let it drop in the pan
3. Wiggle it out/attempt to wiggle it out
4. See what it's catching on and remove it/slide it/cut it/persuade it
5. Cuss, swear, cleanup the cuts, tell the wife it's alright and I'll be in shortly (knowing that you will not be)
6. Lift motor and loosen diff mount
7. Wonder why you didn't do that in the first place
8. Come back on here with pictures and a writeup on your latest experence.
Easier than the 10 steps for AA mine only has 8
Old 11-20-2009, 06:05 AM
  #686
92 TOY's Avatar
Jack-stands at RED ARROWS??
Floor jack at YELLOW ARROW (holding diff)??
Old 11-20-2009, 06:06 AM
  #687
Lumpy's Avatar
I would think so you will want them outta the way a bit.
Take your front tires off as well so that the truck isn't as high when you get the stands under there.
Old 11-20-2009, 06:07 AM
  #688
Lumpy's Avatar
You can put the stands on the A arms...
Old 11-20-2009, 06:09 AM
  #689
92 TOY's Avatar
UMMMM...12 steps for AA
Yeah, sitting here waiting for the Doctor to call......so I'm in and out.
Old 11-20-2009, 06:26 AM
  #690
Lumpy's Avatar
Ok you got me I guess that's why I didn't pass. I only did 10.
No really never been, just took a guess 10 seem about right.
Old 11-20-2009, 06:31 AM
  #691
92 TOY's Avatar
I'm gonna just let that one go...............
Anyway......probably gonna run to SEARS....$24.99....can't really do much with having something like these......they go up to 21''..............so moreroom for me.....I'm in no way heavy but I like to not have heavy metal stuff right against my head.
Old 11-20-2009, 06:32 AM
  #692
Lumpy's Avatar
They match your trucks.
Lets hope they don't stay that nice and clean for long!!!
Old 11-20-2009, 06:34 AM
  #693
92 TOY's Avatar
yeah...that's why i picked them...LOL!!
Let's hope they don't get blood-splattered!!!!
Old 11-20-2009, 06:46 AM
  #694
Lumpy's Avatar
Definitely don't want to see that type of carnage.
Old 11-20-2009, 06:48 AM
  #695
92 TOY's Avatar
hey, it's me...ya gotta expect some kinda something-gonna-happen.....
Old 11-20-2009, 06:50 AM
  #696
xxxtreme22r's Avatar
make sure you got a pry par set, you gonna need it to get that diff back in. especially the front mount. I didnt realize those wires were there, since you do have an auto, I got the 5sp. Maybe thats why some of us had to drop the diff and some of us hasn't.
Old 11-20-2009, 07:02 AM
  #697
92 TOY's Avatar
I appreciate the honsety man......I believe it wil not be easy.
I'm assuming I shouldn't do anything without the jackstands.
The automatic trans is a concern in this always.......I have fluid lines running where you guys don't......that was one thing I listed as a concern.....I know with so many posts it gets lost......but i remember it all.......that's why there's so much preparation for me. I want ALL the knowledge 1st....then I will wrench.
I thoroughly appreciate everyone's input.
Old 11-20-2009, 07:03 AM
  #698
92 TOY's Avatar
i'm starvng.
I had stuffed peppers for breakfast.......maybe waffles for lunch.
Old 11-20-2009, 09:23 AM
  #699
those motor mount bolts you circled are the wrong ones, yes those are the motor mounts, however you want to undo the two on each side that bolt the mount to the frame. If I remember right they are 14mm.
Old 11-20-2009, 09:26 AM
  #700
User Requested Ban
theAuthority's Avatar
you're 1 step ahead of me dude.. I dont even own a toyota anymore
Quick Reply: 92 TOY's 22re / crapped out / gotta start somewhere / thread
