92 TOY's 22re / crapped out / gotta start somewhere / thread
#2662
Oooo ya thank's I'll have to add it.
Vacuum hoses suck!!!
Hahahahahaha that was funny!!!
If you follow the diagram you should be just fine.
#2663
OK...i have the laptop in the garage now....i'm gonna mess with the ditributor cap........take the cap off right????
#2665
gonna say the answer is yes....and about 20 dead spiders fell out....they know i hate spiders!!!
anyway , i have to read the books and stuff, but the ditributor has a tooth marked....i assume this is the one to line up?
PS...can't download pics to this laptop....LUMPY...you have to work on that for me.
#2667
Hey 92,
What I did was slide the rotor about 1/4 of the way to the right of #1, the as I slid it in, the gear turned the distrib. back to where the rotor back-clicked right to #1.
Hope that's helpful, but it probably sounds more like "goo goo ga ga, blah blah", hahaha. Sorry, I'm not always the best with these terminologies.
GOOD ON YA!
GOOD ON YA!
#2668
I think (memory going a bit) if you have the rotor about 9:00 when installing the distributer it will turn clockwise to about 11:00 where it should for for TDC. "I think"
#2669
OK....i'm back up on the big computer.....Hayne's manual was worthless.
Now...what do i know, but do all distributors have this little nub sticking out?...does that denote something as far as where it should lie with the gear from the cam?
#2673
I presume you made sure the engine is at TDC on #1's compression stroke. If it's not you'll be 180 degrees off.
My 22R distributor doesn't have that nub. It's hard to tell from pictures, but your rotor position looks about right. You could try holding the dist cap in position and eyeball whether the rotor points at #1.
Looks like your rotor is getting tired.
