92 TOY's 22re / crapped out / gotta start somewhere / thread
#2181
good morning all.
short list today.
have to run to work for a few hours.
i plan on tightening up those mounts as per the FSM and then while i still have the room to maneuver under there, put back that rubbery plug thingy on the front of the transmission...and the tighten up the front driveshaft for good.
then it's gonna be lowered down...woohoo.
then i will start on the exhaust side, that little coolant hose, pipes and finally exhaust manifold and power steering......loop the belts around everything, start to button up the intake side and then much closer to starting this up.
short list today.
#2183
hahahahahahaha
no, it didn't happen......off next 3 days.....1st 2 are mine, 3rd..not so much....so in the next 2 days I plan on getting a ton done.
#2184
steering damper torqued to 19ft/lbs.........CHECK
diff mounts x 2 torqued to 123ft/lbs...........CHECK
front driveshaft bolts x 4 with threadlocker RED......CHECK
#2188
Good deal moving right along. Good thing you didn't pull one of my moves and forget to go back and torque those.
Might just be me but I don't find Floyd very inspirational when I'm trying to get something done. when I hear that I just want to sit and well not to much.
#2191
clears my head..........although i did pause it for a minute when i was getting the truck off the stands.
i think i will go back and re-torque those mounts because now that the truck is back on the ground it is essentially pushing them up.....just me being OCD about it , maybe.
#2192
hose on
had to rummage through the garage to find a new thermostat gasket...found it....and NEW 2-valve thermostat going in....
#2198
now is when i collect my thoughts a little a do some research......it appears i have 3 brackets that hold on the power steering stuff....so have to go back and look at my pics and posts from other guys to see what the hell i do there.
