92 TOY's 22re / crapped out / gotta start somewhere / thread
Old 04-22-2010, 05:20 AM
  #2141
Magnusian's Avatar
Location: Downtown Heckronto, Ontario, Soviet Canuckistan
Originally Posted by 92 TOY
and if i recall correctly, i can't quite fit a socket wrench on those and had to use a regular wrench and an adjustable one.
Try using an extension on your ratchet, I did this when taking my drive shaft bolts out and it made it a lot easier to get the socket on the bolts.
Old 04-22-2010, 05:22 AM
  #2142
92 TOY's Avatar
i think i remember stuff being in the way.
for now, it's good like it is, just will have to come back to that.
gonna go out an see what happens when i try raising the diff....IE: how much of a beyotch this is going to be.
Old 04-22-2010, 05:23 AM
  #2143
92 TOY's Avatar
Originally Posted by tiger
great job your getting there bet your seeing the light at the end of the tunnel ha you talk about being out of shape i jus hurt my back sun pulling a trans and transfer case out of a 86 toy to put in my 87 (think the syncro"s r going out of mine so need a good one) now 3 chripratic trips later im still kincked up grrrrrr
my secret is usually Motrin....but i didn't take any.....so i guess i am OK.
Old 04-22-2010, 06:19 AM
  #2144
Lumpy's Avatar
Motrin...isn't that for cramps???
Old 04-22-2010, 06:38 AM
  #2145
92 TOY's Avatar
actually that's MIDOL, which is motrin,or tylenol or naproxen (alleve) depending on which one YOU need....hahahahaha...good call.
Old 04-22-2010, 06:39 AM
  #2146
92 TOY's Avatar
Ok...break time
I must say, I impressed myself again.
diff is mounted to the frame once again...not torqued yet, but almost "Levi" tight.
Old 04-22-2010, 06:49 AM
  #2147
92 TOY's Avatar
pics....
so this is how it starts
1st problem...binding on the driver's side....what to do? what to do??
I'll get my helpers....
the I took a vote and voted against doing that. so with some intricate jack-work...a little here, a little there....and on and on...i got it close to where it needed to be
then with a little tug and a push on the ??axle tube...that's what i will call it, i was able to get the hole lined up on the driver's side and made my arms about 6 inches longer with a quick growth spurt and i was able to loosely-but-snug(ly) get that bolt in and tightened up
moving on to the passenger's side, i realized i was going to be doing this side quite blindly.....so a screwdriver through the hole to help line it up just right and then a bolt and it's nut and tightened it down a bit.
next will be to move on to the front and clobber the crap out of the crossmember to get it in place (i assume)
Old 04-22-2010, 06:52 AM
  #2148
Lumpy's Avatar
Good deallyo!!!
I like to see progress!!!
Old 04-22-2010, 06:54 AM
  #2149
92 TOY's Avatar
this truck may be sitting on it's own 4 feet today yet!
Old 04-22-2010, 06:55 AM
  #2150
92 TOY's Avatar
going to see if i could loosely "pin" that crossmember in and "pin" the diff to it.
if this works, i'm gonna poo myself.
Old 04-22-2010, 06:58 AM
  #2151
Lumpy's Avatar
Oooo sorry my bad...
I thought tylenol was different from naproxen/alleve. Hmmmm learn something new everyday. I also thought Motrin was ibuprofen not naproxen. I guess I don't know as much as I thought I did.
Old 04-22-2010, 07:00 AM
  #2152
Lumpy's Avatar
I'm sure you'll be able to get them in...just don't the the latter, I don't think you want to be laying on the floor with that.
Old 04-22-2010, 07:05 AM
  #2153
92 TOY's Avatar
no,no, no.....you are absolutely right.
MIDOL....is a brand name that uses combinations of Ibuprofen (motrin), acetaminophen(tylenol) or naproxen(alleve) and other ingredients such as caffeine and other things to accomplish what they need them to.
this is why people need to read labels before taking over the counter meds and prescription meds at the same time.....you can overdose yourself unintentionally.
darvovet= tylenol and propoxyphene
percocet= tylenol and oxycodone
Midol, Doan's Pills, Goody's Headache powder and on and on, consist of meds that are easily and readily available in other forms under different names...you can cook your liver and kidneys by doing the "more is better" thing for any length of time too.
OK...that's the "medical Minute" of this thread.......back to the show.
Old 04-22-2010, 07:56 AM
  #2154
92 TOY's Avatar
more progress...
more pics...
"LUKE....DON'T FORCE IT...."
um and then this......
and then this happened....
and then, since in Hawaii, this is how you signify that you are done with an important step (thanks ROGERMAN) I bid "adieu" to getting the diff and all that back in.
Old 04-22-2010, 08:08 AM
  #2155
92 TOY's Avatar
gotta find my torque specs, torque everything and then lower the truck back to the ground............................yeeeeeeeeeeeeeee eeeeeeeeeeeeehhaaaaaaaaaaaaaaaaaaaaaaa
Old 04-22-2010, 09:02 AM
  #2156
Lumpy's Avatar
Thumbs up
more progress...
I leave for a bit to get more tile and look what I get back too??? Jars like that scar me!!!!
Enough of that good work man, and remind me again never to work with you alone.
But really good job!!!
Old 04-22-2010, 09:05 AM
  #2157
yotarob2005's Avatar
Hell you are making tons of progress today, and the day is only half over, you might have this thing running sooner than you think!
Old 04-22-2010, 09:12 AM
  #2158
92 TOY's Avatar
i smell bad.
really bad.
front bolt on the diff going side to side is 108ft/lbs......DONE!
diff mounts in those circular areas....123ft/lbs....need to do.
Old 04-22-2010, 09:14 AM
  #2159
92 TOY's Avatar
sorry if it brought back memories....
now my arms are dead again from torquing that bolt and it's bent mount.
Old 04-22-2010, 09:15 AM
  #2160
92 TOY's Avatar
this is the part of the episode where i stop and eat something, try to clean up the house real fast and relax for a bit.
Quick Reply: 92 TOY's 22re / crapped out / gotta start somewhere / thread
