92 TOY's 22re / crapped out / gotta start somewhere / thread
#2123
no work tomorrow, wife is working **yay**.......tomorrow's episode will be to start putting all the diff stuff back.....start with re-attaching the front driveshaft and he try to line up the top mounts....then on to the crossmember.
#2126
Yeah I've been caught up with school. I've lost some of my momentum and I still have the CEL and miss... Give me one good weekend and maybe I might get it done. The engine jacking method works but you have those auto lines on top.
#2127
if i had figured out early enough that the one diff mount was binding against the frame and i was going to gain another inch or so by pushing it off to the side, i probably would have had an easier time and not scraped up my beautiful paint job.
no big deal though.
and really the way i feel, if it leaks, at least i will know from where and why and not get really uptight about it.
no big deal though.
#2129
um, no, i don't want to EVER do that again.
that's OK....as long as you are on here when i need a kick in the butt or some advice....but you are always welcome to help.
#2131
for the heck of it, i just checked the statistics of this thread (not factoring in the STICKY's threads).
#1 in replies
#2 in views
holy crap.
#1 in replies
#2 in views
holy crap.
#2132
so as soon as the 2nd kiddo got on the school bus I snapped this pic...
then i commenced to putting the bolts back...temporarily. finger tight for now, but will use red locktite as i can see green-ish locktite on them so i assume they need it.
i'm not quite sure why i had to use the "match marks" as the FSM says to do, but my little model paint job did the trick. just a little nudge here and there and i was able to get everything lined up just right and place the bolts with no effort.
#2134
and if i recall correctly, i can't quite fit a socket wrench on those and had to use a regular wrench and an adjustable one.
#2136
that pan really was a complete pain and then some.....it can be done as has been posted by me, but OY!
today, try to get the diff all back in place and then lower the truck back down to the ground....mind you, it's been a good foot up in the air for several months and makes for a long reach for alot of the stuff.
#2137
really I'm just reversing my steps.....i won't exactly tighten it down for good just yet. it's just with the multiple articulations of that diff, it's kinda like arm wrestling an octopus. i want to at least use the driveshaft-leaning-on-the-swaybar to be an extra set of hands for me.
#2139
great job your getting there bet your seeing the light at the end of the tunnel ha you talk about being out of shape i jus hurt my back sun pulling a trans and transfer case out of a 86 toy to put in my 87 (think the syncro"s r going out of mine so need a good one) now 3 chripratic trips later im still kincked up grrrrrr
