92 TOY's 22re / crapped out / gotta start somewhere / thread
#2021
after you get that oil pan on you can come up here and change out my oil pan gasket for me. ENGNBLDR Rock gasket not doing well at all and I got only about 2000 miles on it.
#2022
without me re-reading all the specs on the 1987 oil pan.....can you get away with an FIPG kinda fix?
that is a damm shame, considering what a pain in the Dartos Tunic (hehehehe) it is to access the pan.
#2025
I am gonna try the fipgish (rtv) fix, but I had already rtv'd it. maybe I wasn't supposed to in the first place or used the wrong color? I always forget which color rtv to use where. Fuel, water, oil etc etc.
#2026
I'm thinking black is black.....I insisted on using the Toyota FIPG because I really don't want to do that part again......I'm gonna assume Black RTV is the equivalent to it though.
#2028
If I rememer right, mine had a gasket (was not cork) and that oem gasket was held in place by some beads that were run of either black or dark grey FIPG.
I might have had the oil pan bolts torqued down too much as well I don't know. The torque specs on those tiny bolts are real low though. And remember also I had to take this pan off from the beginning twice. That I am sure didn't help matters either.
#2029
it's like 8 or 9ft/lbs.
took a pic of the page, not sure if it's readable...have the book right here...Chilton's 1970 to 1988 repair manual...
#2033
good point...i'm gonna go out on a limb and say you are probably as safe if not safer just using the sealer stuff.
#2034
Neither the FSM or my Chilton say to use a gasket, they give a procedure to fill the little grooves on the pan with FIPG. Napa does offer a gasket, but it looked cheap to me so I decided against it.
#2036
my imagination does not serve me well in trying to figure out how to place a gasket on that.... it's a 1-piece right?? so you have to get that pan clear of the strainer and all that just to fit a new one on....versus dropping the pan enough and giving due-diligence to cleaning it up and using the right amount of spooge on it.
