92 3VZE has spark, won't start. 80A fuze blown.
I have a 92 3VZE. one day after a few weeks without driving it I went to start it, and the battery started smoking. It has a crack in the bottom of it. I replaced the battery and all the sudden nothing worked when I turned the key. No click, no crank, nothing. The only thing that worked was the headlights. I found out that the 80A fuse was blown. I replaced that, and now it'll crank, but it still won't start. I took a 12v tester and tested the fuses, replaced a few just incase. I then replaced the ignitor module, and coil. Tested wires coming out of coil and have spark. Still won't start though. I also tested the relays for EFI and started in the fuse box, both are good. Any idea?
phorensic
10-19-2015 07:54 PM
