91 transmission removal/clutch issues
Old 11-13-2011, 02:20 PM
GROUNDHAWG's Avatar
before you drop the tranny,slide it back about six inches to keep from hitting the input shaft on the clutch
Old 11-16-2011, 12:50 PM
oriana'smygirl's Avatar
Thanks guys you are all the best. Hunting season has kind of put a bit of a hold on this for a few days plus the flu has kicked the sh@! out of me but feeling better and deer are not moving so going to work on it now. I will keep you posted and am sure there will be more questions to come
Old 11-23-2011, 02:31 PM
So I go tthe drive shafts off and pulled the starter! now on an earlier post I was thinking that I hit a bird or something well after I pulled the starter off I found a bunch of crap and it looks like burnt and destoryed belt parts?? Does the clutch or anyting in that part of the tranny have belts? I am guessing not!!! What about the clutch disc would it be made out of some kind of fiber? Still going ahead with the tranny removal looks like the last guy's made a mess so trying to make that better. I will post some pic of the hot rod and the progress as I get to it. Kind of cold here and no heat in the shop so work has once again slowed down. -28C here.
Old 11-23-2011, 02:54 PM
bmcghie's Avatar
The only thing I could think of inside the bell housing that looks like a shredded belt would be the clutch disc itself. The disc has a kinda fibrous friction surface on the outer part of each side... but I dunno if that would look like a messed up belt if it was ruined.
How would it get ruined anyways? Maybe the PO left some crap in the bell housing that he shouldn't have?
Liadrin
04-25-2022 02:54 PM
mskalmus
05-28-2017 07:51 AM
jjrbus
07-17-2015 07:06 AM
Poncho0206
07-10-2015 06:21 PM
madxman21
07-09-2015 10:26 AM
Quick Reply: 91 transmission removal/clutch issues
