91 4Runner transmission fluid change
Hey guys I'm new to the Toyota 4Runner but definitely not new to Toyota (I have had an MK3 supra for quite a while)
Anyways, I have a question, I bought a 91 4runner 3VZE with what I believe is the R150F manual transmission and I am unsure what fluids I can use to change the trans fluid out. I am aware of MT90 (a pain to get without ordering) but all other 75w-90 states that they are GL-5 which is too slippery. What have you guys used and is there an alternative to the Redline MT90? I am ordering some soon but if there is something that I can find locally ai will use it to hold me over.
Thanks in advance!
Thanks in advance!
That's fine. In my experience with GL-4 the difference is barely noticeable. And generally speaking not worth the extra cost. I used to think so. But I've all but given up on the notion. Then again I've never used the redline "magic sauce". Probably never will either. Since it's DEFINITELY not required.
Turns out I'm wrong on the no gasket. Change that to a none required. I've got 3 R150Fs and 2 VF1As. None have gaskets on the fill or drain plugs. None leak a drop without them. I've seen the aluminum gasket. For whatever reason the rear diff on my 90 still has one on the fill plug(only one I've ever seen on a fill plug). And every diff drain plug I've ever seen has one.
Mhkabler95
02-12-2016 11:06 PM
captainslow
02-08-2016 10:10 PM
