91 4runner 3vze crazy high idle cold and warm
This is making me crazy. The idle is 2k plus the idle screw is all the way in. No intake leaks that I can find, vac line was cracked fixed still same problem. Checked throttle body and TPS all ok. Only thing left to check is the iac valve. How do I check it the screw is all the way in so maybe that is the problem.
I took the throttle body off and found the coolant passage for the iac valve was plugged up and so was the iac valve. I took jb weld and filled the air hole in front of the butterfly valve and put it all back together. With the idle screw turned out 2 turns I now have 850rpm idle no more surging or high idle..... cost 4 bucks for jb weld. After sitting for close to a year with various problems it is now on the road. Currently has total chaos kit on it so next project is linking the rear end.
