91 3.0 intake problem?
wondering if anyone else has had problems with their vehicles involving the air intake. My Runner runs rough, hardly any power. It’s definitely fuel related because it runs super rich, so I know it’s not the fuel pump, there’s no gas in the vacuum line on the fuel pressure regulator so I don’t have a reason to believe it’s that, brand new spark plugs and wires and distributor looks just fine, and I read something online that it could be problems with/partially clogged. The vehicle sat for few years so it wouldn’t surprise me if something got sucked up in there. Just looking for some ideas, thanks.
Does it have good spark. My truck had a Spark that wasn’t constant when I put a spark plug tester on a plug wire. It was a very random kind of spark and it was running rough. Tried a distributor I had laying around and presto smooth idle/spark and no more surging at 1/8 throttle. Also when I put a timing gun on it the span of the mark was like 30 degrees it was hopping around. Now it only varies about 3 or 5 degrees with good distributor. My intake makes a funny groggy sound once and a while that’s why I clicked on this thread. If it’s not the dist. Maybe clogged injectors or evap leak. Is there a hissing sound? my pcv hose was loose and leaking so I replaced it the other day but it didn’t really make a difference.. that was before I replaced the dist.
Do you have a Haynes manual? did you get the old gas out of there? Fuel filter clogged, timing, spark plug gapped incorrectly, I just got new denso spark plugs and only one of them was perfectly gapped. clogged fuel lines. Do a fuel pressure test. Compression test. maybe advance the timing a little and see if that helps. But advancing the timing may just mask the problem. Get a timing light on it to be sure. I have mine like 3 degrees advanced.
89whitetoyota
11-10-2008 11:21 AM
4rnr
09-15-2006 06:31 PM
DN1911
07-25-2006 06:57 AM
BOSTON4RUNNER
14
11-17-2004 07:00 AM
