90 vs 94 alt on 3.0
90 vs 94 alt on 3.0
I have a 90 3.0 and I bought a bunch of used parts for real cheap and they came from a 94 3.0
my alt went bad, I have the one from the 94 but it has a diffrent plug, but I have the wiring harness so i could spilce it in
is this ok to do and has any one done this?
any write ups?
I dont want to have to buy a new one when I have a good used one laying around
any write ups?
What went bad with original alt? If it's just the brushes (typical), replace them.
Alternatively, swap the rectifiers (with plugs) between alts. It's an easy task.
what are the rectifers?
is that just the pug in the back of the alt?
I was thinking of just swapping the plug and butt conect together.
I think this will work out just fine, but I want someone elses opion
NO SPLICE AND DICE needed.
I did the exact same thing, had my alt go out on my 90 v6, went to a slavage yard and got one off a 94. You just take apart the plug. Take the orginal one off of your old alt and put it on the new. Works perfect.
I fixed it by swapping out the plug, i will have the old one repaired now that it is out.
Thanks for everyones help!!!
now if I can just pull that darn PCV valve with out pulling the intake....
scott90
10-04-2015 09:21 AM
sonorn67
09-19-2015 05:39 PM
